How is the Intensity of Electric Field Related to the Permittivity Constant?
The discussion revolves around the relationship between the intensity of an electric field and the permittivity constant, specifically in the context of transitioning between different unit systems (SI and cgs). Participants are examining the equations related to the intensity of the electric field.
  • Participants are attempting to understand the transition between two equations for intensity, questioning the role of the permittivity constant and its value in different unit systems. Some are exploring the implications of using cgs units versus SI units.
The discussion is active, with participants clarifying the definitions and units involved. There is acknowledgment of the differences between SI and cgs units, and some guidance has been provided regarding the conversion of constants.
There is mention of using "cgs" units and the implications this has on the value of the permittivity constant. Participants are also checking assumptions about the units and definitions being used in the equations.
n0_3sc
Can anyone explain how to go from:
[tex]I_s = \frac{nc\epsilon}{2} |E|^2[/tex]
to
[tex]I_s = \frac{nc}{8\pi} |E|^2[/tex]
That means [tex]\epsilon[/tex] is [tex]\frac{1}{4\pi}[/tex]...I can't find that anywhere.
to
Is your source using something like statcoulombs as units? I think the units are defined so that [tex]\epsilon_{0}[/tex] is set to 1...
It says its using "cgs" units.
By the way [tex]\epsilon[/tex] I quoted, is the same as [tex]\epsilon_0[/tex].
Your first equation is in SI units. The epsilon there is epsilonzero.
The second equation is in cgs gaussian units.
To go from SI to gaussian, let 4piepsilonzero-->1.
Ahh ok - thanks a lot pam.
  • · Replies 17 ·
