Question about the notation in Quantum Physics
The discussion clarifies the meanings of specific Dirac notations in quantum physics, particularly \langle \phi \rangle and |\phi|. The notation \langle \phi \rangle is defined as \langle0|\phi|0\rangle, representing the vacuum expectation value of a field in second quantization formalism. The term |\phi| refers to the modulus of the wave function, which is a complex function mapping R^3 to C. The conversation emphasizes the importance of understanding these notations within the context of Hilbert spaces and their properties.
  • Understanding of Dirac notation in quantum mechanics
  • Familiarity with Hilbert spaces and state vectors
  • Knowledge of wave functions and their properties
  • Basic concepts of second quantization formalism
  • Study the properties of Hilbert spaces and their applications in quantum mechanics
  • Learn about the implications of second quantization in quantum field theory
  • Explore the mathematical foundations of Dirac notation and its usage
  • Investigate the significance of vacuum expectation values in quantum physics
Quantum physicists, students of quantum mechanics, and researchers interested in the mathematical formalism of quantum theory will benefit from this discussion.
princeton118
Does the [tex]\langle \phi \rangle[/tex] means [tex]\langle0|\phi|0\rangle[/tex]?
What does [tex]|\phi|[/tex] exactly mean?
<B> means <y|B|y> where y is some given wavefunction.
I'd guess your other one should have a square in it in which case it would mean modulys squared or in other words the complex conjugate of phi times phi
I think that probably all the notations you used mean different things:
DIRAC NOTATIONS:
1.|psi> is a ket that lives in a hilbert space, math speaking is a state vector which belongs to a projective hilbert space, ie it is a ray.
2.If the hilbert space is separable, you get the complet. relation---> Sum|n><n|=1;
u can have also generalized basis such as the deltas for x and plane waves for p, and the Sum become an integral.
3.a.You have also <x|x'>=delta(x-x')
3.b. or for a separable basis <n|n'>=delta_nn' (the last delta is a kronecker one).
4.Importamt <x|psi>=psi(x) and it is a complex function psi:R^3----->C
the wave function!
Now you can get the meaning of |psi|= the modulus of the wave function, while for the first notation <phi>=<0|phi|0> you have 2 choices i think:
a) it is a second quantization formalism, which mean the vacuum expactation value of a field.
b)Or, if phi is an observable (P,H,L...), it can be the average over the ground state...
ususally when you start reading a book the conventions are displayed..
hope that helped..
marco
