What Is the Role of J x B in Rotating Magnetic Field Current Drives?
  • Context: Graduate
  • Thread starter Thread starter Jdo300
The discussion centers on the role of J x B in rotating magnetic field current drives, particularly in the context of the Translation, Confinement and Sustainment (TCS) Experiment at the University of Washington. The RMF current drive technique is highlighted as a steady-state method for sustaining high-temperature field reversed configuration (FRC) plasma. The experiment aims to benchmark this technique against theoretical predictions and has successfully extended the FRC lifetime by a factor of three with 1 ms pulses. The inquiry also raises questions about the applicability of J x B equations beyond plasma to conventional conductors.
  • Understanding of J x B equations in electromagnetism
  • Familiarity with rotating magnetic fields and their applications
  • Knowledge of high-temperature plasma physics
  • Basic principles of magnetic flux and current drive techniques
  • Research the principles of rotating magnetic field current drive systems
  • Study the effects of J x B forces in different conductive materials
  • Explore the theoretical predictions related to FRC plasma behavior
  • Investigate the implications of steady-state current drive techniques in plasma confinement
Researchers in plasma physics, electrical engineers working with magnetic fields, and anyone interested in advanced current drive techniques in fusion energy applications.
Jdo300
Hello All,
I have had some interest in the effects of rotating magnetic fields and was doing some research on the subject when I came across the following paper published from the University of Washington:;
http://wsx.lanl.gov/Publications/RSI-RMF-Tobin-paper.pdf
The paper discusses some experiments involving a high power, high speed rotating magnetic field. I didn't read through the entire paper but there was one spot on the first page that really caught my attention:
"The Translation, Confinement and Sustainment (TCS) Experiment located at the Redmond Plasma
Physic Laboratory (RPPL) of the University of Washington was designed to apply, for the first time, a
rotating magnetic field (RMF) to a high-temperature field reversed configuration (FRC) plasma (Te ~ 100
eV and Ti ~ 300 eV) [1]. The RMF current drive technique is a special case of the more general j x B
current drive scheme, by which electrons are “pulled” along with the rotating magnetic field [2].
Unlike
inductive current drive systems, RMF current drive is steady state. The RMF is used for the purpose of
building up and sustaining the magnetic flux of the FRC. The exp erimental goal is to benchmark this
current drive technique against theoretical predictions, and to determine the robustness of the FRC plasma
to this external perturbation. An initial goal for the RMF system was to extend the lifetime of the FRC by a
factor of ~3; this goal has already been achieved with pulses lasting 1 ms. It was anticipated that a 1 ms
pulse would become limited by particle inventory rather than resistive flux losses. At present particle
inventory is not limiting lifetime, exactly why is not yet understood."
I am particularly interested in the part that I highlighted in boldface. I was wondering if anyone here may know anything about "rotating magnetic field current drive" systems, and how the J x B equations fits into this? I am very interested in learning more about this. Does it only apply to plasmas or could the effect take place in regular wires too?
Thank you,
Jason O
Hi Jason,
I'm not an expert on rotating magnetic fields, but I do know a bit about the J x B equations. The J x B equations are used to describe a current that is driven in a conductor by a changing magnetic field, which results in a force that is perpendicular to both the current and the magnetic field. This type of force can be used to drive the plasma contained in your experiment, which describes the rotation of the magnetic field. I'm not sure if this effect can be applied to regular wires, but it definitely applies to plasma.
