Detector Coverage and Power of Electric Dipole: Calculation and Diagram
  • Thread starter Thread starter stunner5000pt
    Detector Dipole
The discussion focuses on calculating the fraction of solid angle covered by a detector placed 1 meter away from an electric dipole with a radius of 10 cm. The apex angle of the cone formed by the detector is determined to be 5.7 degrees, leading to a solid angle calculation of approximately 0.00248 steradians. Additionally, the total dipole power detected, assuming 100% efficiency, is derived using the formula for dipole radiation power density, integrating over the solid angle.
  • Understanding of electric dipole radiation and its properties
  • Familiarity with solid angle calculations in spherical coordinates
  • Knowledge of integration techniques in multivariable calculus
  • Proficiency in CGS units and their conversion to SI units
  • Study the derivation of electric dipole radiation formulas, specifically dP/dΩ.
  • Learn about solid angle approximations and their applications in physics.
  • Explore integration techniques for spherical coordinates, particularly in the context of electromagnetic theory.
  • Review the differences between CGS and SI units in the context of electromagnetic calculations.
Physics students, electrical engineers, and researchers in electromagnetism seeking to understand detector coverage and dipole radiation calculations.
stunner5000pt
A detector hjaving a radius 10 cm is placed 1 m away from an electric dipole. What fraction of total solid angle does the detector cover and what fraction of total dipole power does it detect (assuming 100% detection efficiency)
2. The attempt at a solution
I drew the diagram as well maybe that will help. In any case, i think the detector will make a cone (?) with the dipole.Since the base of this triangle has radius of 0.1 m and the height of the triangle is 1m, the apex angle is 5.7 degrees or [itex]57\pi/180[/itex]
the total angle swept by the triangle is thus
[tex]\int_{0}^{2\pi}\int_{0}^{5.7\pi/180}\sin\theta\ d \theta d\phi = \frac{5.7\pi}{90}[/tex]
the total angle swept by a sphere is 4pi so the fraction is simply the answer above divided by 4pi. Is that correct?
You set up the integral correctly, but I get (I find it nice to work exactly when possible, although you'll have to round eventually anyway, so this isn't really that worth it)
[tex]\int_{0}^{2\pi}\int_{0}^{\theta_o}\sin\theta\ d \theta d\phi = 2 \pi \left( -\cos \theta |_0^{\theta_o} \right) = 2\pi(1 - \cos\theta_o)[/tex]
Or using [itex]\theta_o = \tan^{-1} (0.1)[/itex]:
[tex]0.1 = \tan \theta_o = \frac{\sin \theta_o}{\cos \theta_o} = \frac{\sqrt{1-\cos^2 \theta_o}}{\cos \theta_o}[/tex]
[tex]\Rightarrow \cos \theta_o = \frac{1}{\sqrt{ (0.1)^2 + 1 } }[/tex]
So the integral becomes:
[tex]2\pi \left(1 - \frac{1}{\sqrt{ (0.1)^2 + 1 } } \right) \approx 0.00993 \pi[/tex]
For a solid angle of (dividing by [itex]4\pi[/itex], as you say) .00248Usually, though, it suffices to approximate the solid angle by taking the area of object and dividing by [itex]4\pi r^2[/itex], where r is its distance from the dipole. This ignores the curvature of the sphere, and so is not exact, but is usually a good approximation. In this case, you would get [itex]\pi(0.1)^2/4 \pi (1)^2 = 0.0025[/itex], which is slightly off, but not too bad for most purposes.
Thanks a lot
Ok now for the fraction of total dipole power detected (assuming 100% detection efficiency)
the total dipole power detected is given by [tex]\frac{dP}{d\Omega}=\frac{q^2 a^2}{2\pi c^3}\sin^2\theta[/tex]
So i need to integrate the above expression w.r.t. omega?
[tex]P = \frac{q^2 a^2}{4\pi c^3} \int_{0}^{2\pi}\int^{\theta_{0}}_{0}\sin^3\theta d\theta d\phi[/tex]
here theta zero is the angle calculated in the first section??
Is that correct?
I am working in CGS units so the formulas will look like their SI counterparts (obviously)
12K
  • · Replies 19 ·
