Thread Closed
File not found in Java
Share Thread Thread Tools
Mar22-08, 11:38 AM   #1
Hello. I am having some trouble getting a java program to work. I am supposed to make a program that takes a word and a file name, and finds all lines in that file that contain that word.
The word that I chose was "try", and the file was "Sgrep.java"
Here is the main method:
Code:
class main {
public static void main(String[] args){
        if(args.length != 2){
            System.out.println("Usage: java Sgrep <string> <filename>");
            return; }
        Sgrep task = new Sgrep(args[0], args[1]);
        System.out.println(task.getFilename());
        System.out.println(task.search());
and here is the class Sgrep:
Code:
import java.io.*;
public class Sgrep {
    String find;
    String file;
    Sgrep(String fin, String fil)
        find=fin;
        file=fil;
    public String getFilename() {
        return file;
    public String search() {
        FileReader read;
        String currentLine;
        String answer = "";
        if(find == null) {return "";}
        try {
            read = new FileReader(file);
        catch (FileNotFoundException e) {return "File not found";}
        LineNumberReader reader = new LineNumberReader(read);
        while(0==0) {
            try {
                currentLine = reader.readLine();
            } catch (IOException ex) {
                return answer;
            if(currentLine.indexOf(find) != -1) {answer = answer + "\n" +
                    reader.getLineNumber() + ":\t" + currentLine;}
I put a return statement after the FileNotFoundException that prints "File not found", and that is what I have been getting.
Did I do anything wrong that is not allowing the program to find the file? Because it is supposed to work.
I would appreciate any help,
Jeans
This is important, I need this done by this weekend.
EDIT: I got it to work. The assignment sheet had given an example output that showed the file name as Sgrep.java, however, in order to get the program to recognize the file, I had to type in the entire target (C:\Users\User\Sgrep\src\sgrep\Sgrep.java). That is two hours of my life I'll never see again .
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Thread Closed
Thread Tools
Similar Threads for: File not found in Java
Thread Forum Replies
Java: writing pictures to a file Programming & Comp Sci 1
how do display/generate webpage content with info from an array in a .java file? Programming & Comp Sci 1
problem about .java file and email Computing & Technology 5
excel file won't open under java script tree menu Computing & Technology 0
