Coulomb's law universal or not?
The discussion revolves around the concept of "universal laws" in physics, specifically focusing on Coulomb's law and its applicability compared to other laws such as Gauss's law and Maxwell's equations. Participants explore the conditions under which these laws apply, their limitations, and the implications of being classified as universal.
  • Some participants question what constitutes a universal law, citing that Coulomb's law may not be universal as it only applies under certain conditions, such as static charges.
  • Others argue that Coulomb's law can be applied to charge distributions by considering individual charges, suggesting it retains some level of universality.
  • It is noted that Coulomb's law does not account for moving charges, which introduces complications that require Maxwell's equations for a complete description.
  • Some participants assert that Gauss's law is universal because it is one of Maxwell's equations and applies in broader contexts than Coulomb's law.
  • There is a contention regarding whether Coulomb's law is truly inverse-square and how that relates to its universality.
  • Several participants express uncertainty about the definition of "universal," indicating that interpretations vary and that there is no consensus on the matter.
Participants generally do not reach a consensus on whether Coulomb's law is universal. Multiple competing views remain regarding the definitions and implications of universal laws in physics.
Limitations in the discussion include varying definitions of "universal," the dependence on specific conditions for the applicability of Coulomb's law, and unresolved questions about the relationship between Coulomb's law and Gauss's law.
manjuvenamma
What exactly is meant by universal law? I have read in a book a that Ohm's law is not a univeral law. I somewhat understood that as Ohm's law is not obeyed by all materials and not always. But I read now in another book that Coulomb's law is also not a universal law. Now I am beginning to wonder what is a univeral law.
Coulomb's law only works for a point charge, and not for all charge distributions. As it only works in certain situations (as does Ohm's Law), then it is not universal. A universal law will work in any situations.
I did not get what you mean by the law not applicable to charge distributions. For charge distributions too we can still apply the law individually for each charge and get the results. Like we have the force calculations for a line charge or sheet of charge. Even the gravitational law consider bodies with masses as particles, so is gravitational law too not universal. You must be right, but I think I am missing a point. If you can elaborate, that will help.
Well you can't just blindly apply Coulomb's law if the charges in question have a velocity or an acceleration.
Coulomb's law is a simplification of Maxwell's equations under specific conditions (electrostatic = no moving charges). The universal law is Maxwell's equations which are hard to solve sometimes. So you use the simpler Coulomb's law where you can and the more complicated but universal Maxwell's equations when you need to.
PS Coulomb's law is not the only simplified form of Maxwell's equations that is in widespread use, but it is the first one that you encounter in a typical course of study.
So why does Coulomb's Law not work for charges in Motion?
-Ataman
Coulomb's law gives you the electric field. If a charge is moving you need to consider the magnetic field also.
Friends,
I agree with you all. I am now convinced/enlightened why the law is not universal. Thanks.
Am I to understand that, in contrast, Gauss' law IS universal. In other words, although you can derive it from Coulomb's law in the context of electrostatics, it is actually applicable outside of that context as well?
Well Gauss's law is one of Maxwell's equations, which are universal, whereas Coulomb's law is not.
there seems to be something wrong with this thread. Gauss's Law is a direct consequence of any inverse-square law. if it's inverse-square (and additive, i.e. superposition applies), then Gauss's Law applies.
so is the implication here that Coulomb's Law is not inverse-square?
BTW, from a POV of classical, non-relativistic physics, yes Coulomb's law is lacking because it does not describe the electromagnetic interaction. but if Special Relativity is considered, that plus Coulomb's Law suffices, i think.
i would say that the premise of the question (and many of the responses) is wrong. Coulmb's Law is quite universal. but like other universal laws, it's not the only one.
Gauss's law and Coulomb's law are equivalent. You can derive either from the other quite easily. By "not universal" I simply meant to imply that Gauss/Coulomb is only one part of Maxwell, which is the "universal" law. Gauss/Coulomb always applies, but whenever you have moving charges it is insufficient to predict the behavior without the other Maxwell equations.
OK, I am fine with that too. "Universal" but not "complete".
there seems to be something wrong with this thread. Gauss's Law is a direct consequence of any inverse-square law. if it's inverse-square (and additive, i.e. superposition applies), then Gauss's Law applies."
Sorry the point I was trying to make was that Gauss's Law always applies as it is one of Maxwell's equation, and Coulomb's law is only a solution of the Maxwell equations when things aren't changing with time. Does that make it not universal? It depends on what one means by universal.
it is not that either. it is what is usually enumerated as the first of Maxwell's equations.
[tex]\nabla \cdot \mathbf{E} = \frac {\rho} {\epsilon_0}[/tex]
is the differential expression of
[tex]\oint_S \mathbf{E} \cdot \mathrm{d}\mathbf{A} = \frac {Q_S}{\epsilon_0}[/tex]
while that is a direct expression of Gauss's Law, that expression follows directly from the fact that Coulomb's Law is inverse-square and submits itself to superposition.
what i usually mean by "universal" is that it is as applicable to the aliens on the planet Zog as it is to us here.
Ok sure, but if [tex]\frac{\partial \rho}{\partial t} \neq 0[/tex], then [tex]\vec{E} = \frac{q}{4\pi\epsilon_0r^2}\vec{r}[/tex] will not be a solution of Maxwell's equations. The impression I got from the initial post was that 'universal' is to mean 'always applies'.
I think that is too liberal a definition. By that definition Ohm's law is universal too.
To the OP: I think these last few posts make it clear that there is no clear definition of a "universal" law.
  • · Replies 44 ·
  • · Replies 19 ·
