Half Wave Antenna Vector Potential Calculation?
  • Thread starter Thread starter stunner5000pt
    Antenna Wave
The discussion focuses on calculating the vector potential, electric and magnetic fields, and the power density of two half-wave antennas positioned at (\Delta/2,0,0) and (-\Delta/2,0,0). The current for each antenna is defined as I(z,t)=\hat{z} I_{0}\cos\omega t\sin k(\frac{d}{2}-|z|), where k=\omega/c. The vector potential A is derived using the retarded time approximation and the integration of the current density, with considerations for the radiation zone and the distance between antennas.
  • Understanding of vector potentials in electromagnetism
  • Familiarity with half-wave antennas and their configurations
  • Knowledge of retarded time and radiation zone approximations
  • Proficiency in calculus for performing integrals in electromagnetic contexts
  • Study the derivation of vector potentials in electromagnetic theory
  • Learn about the radiation fields of dipole antennas
  • Explore the implications of the far-field approximation in antenna theory
  • Investigate the integration techniques for multiple antenna systems
Students and professionals in electrical engineering, particularly those specializing in antenna design and electromagnetic theory, will benefit from this discussion.
stunner5000pt
Vector Potential
Consider two half wave antennas each ahving current
[tex]I(z,t)=\hat{z} I_{0}\cos\omega t\sin k(\frac{d}{2}-|z|)[/tex]
where [itex]k=\omega/c[/itex]
Each antenna has length d and points in the z direction. Antenna 1 is at [itex](\Delta/2,0,0)[/itex] and antenna two is at [itex](-\Delta/2,0,0)[/itex]
a) Find the vector potential A
b) Find the electric and magnetic field
c) Find [tex]dP/d\Omega[/tex]
d) Evalute [tex]dP/d\Omega[/tex] in the X Y plane when the antenna is seaparated by a distance lambda/2. Along what direction is the radiation preferentialy propagated?
In CGS units so...
[tex]\vec{A}(\vec{r},t)=\frac{1}{c}\int \frac{\vec{J}(\vec{r},t_{r})}{|\vec{r}-\vec{r'}|} d\tau[/tex]
So we need the current as a function of z' and the retarded time
[tex]I(z,t)=\hat{z} I_{0}\cos\omega (t-\frac{\mathcal{R}}{c})\sin k(\frac{d}{2}-|z|)[/tex]
where [tex]\mathcal{R}=\sqrt{z'^2+r^2-2z'r\cos\theta}[/tex]
since we want the fields far away (radiation zone), expand
[tex]\mathcal{R}\approx r\left(1-\frac{z'}{r}\cos\theta[/tex]
so then
[tex]\cos\omega (t-\frac{\mathcal{R}}{c})\approx\cos\omega\left(t-\frac{r}{c}\left(1-\frac{z'}{r}\cos\theta\right)\right)[/tex]
[tex]\cos\omega (t-\frac{\mathcal{R}}{c})\approx\cos\omega t \cos\frac{r}{c}\left(1-\frac{z'}{r}\cos\theta\right)+\sin\omega t\sin\frac{r}{c}\left(1-\frac{z'}{r}\cos\theta\right)[/tex]
So then A is calculated like this? make the approximation that [tex]\mathcal{R}\approx r[/tex]
[tex]\vec{A} = \hat{z}\frac{I_{0}}{rc}\int \sin k\left(\frac{d}{2}-|z|\right)\left(\cos\omega (t-\frac{\mathcal{R}}{c})\left(\cos\omega t \cos\frac{r}{c}\left(1-\frac{z'}{r}\cos\theta\right)+\sin\omega t\sin\frac{r}{c}\left(1-\frac{z'}{r}\cos\theta\right)\right) dz'[/tex]
Ok since there are two antennas how should the integration be performed...
should i do for each antenna separately? That is integrate one of them from [itex]\Delta[/itex] to [itex]\Delta+\frac{d}{2}[/itex] and one of them from [itex]\Delta[/itex] to [itex]\Delta-\frac{d}{2}[/itex] ?? And then add the two results?
Thanks for your help!
Since it is a radiation problem, I think you are allowed to assume r>>r' and
kr>>1, which greatly simplifies the problem.
  • · Replies 19 ·
