Thread Closed
Displacement in Simple Harmonic Motion
Share Thread Thread Tools
Mar23-08, 02:34 AM   #1
1. Hi! I am new to this forum. I was wondering if someone could help me with this problem. Thanks in advance!
A 0.27 kg mass is suspended on a spring that stretches a distance of 4.9 cm. The mass is then pulled down an additional distance of 12.5 cm and released. What's the displacement from the equilibrium position with the mass attached (in cm) after 0.42 s? Take up to be positive and use g = 9.81 m/s2.
2. Relevant equations
F=kx
ω(angular velocity)= (k/x)^0.5
3. The attempt at a solution
First I solved for k:
k=mg/x
k=(0.27*9.81)/4.9
k=0.54
Then I solved for the angular velocity:
ω=(0.54/0.27)^0.5
ω=squareroot 2
Then I tried to come up with an equation for displacement using the format:
x(t) = Asin(ωt)
i know that ω=root2
t=0.42
but how do i solve for A?? or what is A? should it be 4.9 or 12.5 or the sum of the two btw please correct me if im wrong in my calculation. thanks!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Mar23-08, 03:25 AM   #2
4.9 cm is the location of the equilibrium position. They're asking you to find the displacement after t seconds relative to the equilibrium position, so set your equilibrium position to 0. From the equilibrium position, they extended the displacement by 12.5 cm.
Mar23-08, 07:29 AM   #3
You know anything about S.H.M equations?
Mar26-08, 12:05 AM   #4
thanks! i got the answer now =)
Thread Closed
Thread Tools
Similar Threads for: Displacement in Simple Harmonic Motion
Thread Forum Replies
simple harmonic motion, finding displacement given time... Introductory Physics Homework 1
Motion of object (simple harmonic motion?) Introductory Physics Homework 3
Simple Harmonic Motion and Wave Motion General Physics 2
displacement in simple harmonic motion Introductory Physics Homework 2
