Thread Closed
Classical Gravity versus GR
Share Thread Thread Tools
Mar23-08, 09:14 AM   #1
I have a question about classical gravity versus GR. If we use Newtonian gravity for a sphere, gravity is zero in the center due to vector addition. So if we were to plot the gravity force versus distance, from far space, to the center of a spherical planet, it starts near zero, climbs until we reach the surface of the planet, and then decays back to zero.
If we use this gravity profile to explain a GR space-time well, in the fabric of space-time, is there a peak in the center of the well? The center point has the same gravity number as distant space so should it have the same space-time fabric height? It would look like a mountain in a hole, with the peak height the same as distant space.
I never see GR explained with a peak in the center, so is this Newtonian gravity peak virtual and the cause of the GR affect? Here one possible explanation, using the particle-wave nature of matter. If we just assume there were only particles without waves, for the sake of argument, the center point would see the most potent particle exchange due to the lowest distance summation. If we assume only waves, without particles, this is more consistent with the zero gravity in the center, due to wave addition. Due to the particle-wave nature both need to be consistent, yet each acting separately lead to two different results. To make these consistent, the particles that should appear in center can not appear there. But due to the conservation of energy, they will still need to appear elsewhere where they are consistent with their wave nature. The result is GR. The contraction of space-time allows nature to get the potential energy of the inconsistent particles into compacted space-time to compensate for the wave-particle inconsistency in the center of gravity.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Mar23-08, 09:50 AM   #2
Recognitions:
Gold Membership Gold Member
The interior solution for a sphere of matter in GR predicts flat space at the center, in agreement with the Newtonian result. This applies to matter with finite pressure throughout and with a regular energy-momentum tensor.
I don't think one can derive GR in the way you suggest.
Mar23-08, 10:10 AM   #3
Quote by Mentz114 View Post
Suppose there is a small cavity at the center, what the space in it would be? "flat" or "Not flat"? Suppose next, if there is a clock in the cavity, would the clock run slow compared with a clock at infinity?
Mar23-08, 10:22 AM   #4
Quote by Xeinstein View Post
The clock in the cavity would run slower than a clock at infinity and slower than a clock on the surface of the massive body. The force of gravity goes to zero as you descend from the surface to the centre. The gravitational potential at the surface is lower than at infinty and continues to get more negative as you descend to the centre. It is the potential rather than the force of gravity that influences clock rates.
Mar23-08, 10:50 AM   #5
Quote by siphon View Post
No. you misunderstand how gravity is modeled in GR. There is no "space-time fabric height". The distortion of space-time has an maximum in the center of a sphere, causing a maximal time dilation there. Free fallers are always drawn towards areas of higher time dilatation. But at a point of locally maximal time dilatation, there is nowhere else to go.
Try this visualization:
http://www.adamtoons.de/physics/gravitation.swf
If you set "initial position" to zero, the free falling object is placed at the center of the sphere. And it stays there because it's geodesic world line doesn't deviate in any space direction. The object moves only trough time by moving straight ahead trough space-time.
Mar23-08, 11:25 AM   #6
Are you sure, that the interior Schwarzschild metric is flat in the center? The only thing, that is required from it, to agree with Newton, is that the worldline of an object resting in the center is a geodesic in space-time. To satisfy this, space-time doesn't need to be flat there. You can have a geodesic with a constant space-coordinate in curved space-time too. The spacial part of the interior solution has a hypersphere-like non-zero curvature at every point, also at the center of the mass. And if space alone is curved there, space-time can hardly be flat.
If the sphere mass had a small cavity at the center, I would of course agree that space-time is flat within the cavity. But the interior Schwarzschild solution considers a filled spherical mass.
Mar23-08, 11:39 AM   #7
Going back to the OP, I think there's a little confusion about two things. First, there's a difference between the gravitational force as a function of r, which is what goes to zero at the center and at r=infinity, and the gravitational potential, which is what is sometimes modeled as a curved sheet with balls rolling around on it.
Second, it wasn't clear to me whether the OP meant a spherical mass shell or a solid sphere - I assumed it was the latter. In that case, you have to invoke the very thin tunnel from the surface to the center to discuss the force at points below the surface of the sphere. Contrary to what I think Mentz114 was suggesting, the force is not zero in this region, but varies as a linear function of r (like a spring) from zero at the center to the value at the surface given by the usual inverse square law, which defines the force everywhere else.
This gives rise to a potential function that has a minimum at r=0, rises parabolically to the radius of the sphere, and linearly out to a max value at infinity. There's no peak at the center, as far as the potential is concerned; that would imply an outward force, which is not the case.
Mar23-08, 11:46 AM   #8
Recognitions:
A.T.:
I'm looking at a metric which when r = 0 goes to ds^2 = dr^2 - c^2dt^2. I interpret this as 'flat', but I could be wrong.
Mar23-08, 01:09 PM   #9
A.T.:
The metric ds^2 = dr^2 - c^2dt^2 is flat, it's the same with metric at infinity, but it can't be the metric in the cavity. Since a clock in the cavity run slower than a clock at infinity
Mar23-08, 01:11 PM   #10
A.T.:
Wikipedia says "The Schwarzschild metric is a solution of Einstein's field equations in empty space, meaning that it is valid only outside the gravitating body. That is, for a spherical body of radius R the solution is valid for r > R. To describe the gravitational field both inside and outside the gravitating body the Schwarzschild solution must be matched with some suitable interior solution at r = R."
It is obvious that an obsever moving down a tunnel to the centre of the Earth will (besides getting very hot) pass a point where the radius is less than the Shwarzchild radius of the Earth's mass but there will be no event horizon at that point. At the centre of the Earth the radius is zero but there is no singularity. This is because the mass within the Shwarzchild radius is less than the Shwarzchild mass.
If we consider only the enclosed mass as the observer descends down the tunnel then the gravitational gamma factor:
[tex] \sqrt{\left(1-\frac{2GM}{c^2R}\right)}[/tex]
becomes (assuming even density distribution):
[tex] \sqrt{\left(1-\frac{2GM_ER^2}{c^2R_E^3}\right)}[/tex]
where [itex]R_E[/itex] and [itex] M_E[/itex] are the radius and mass of the Earth.
The modified formaula contains no singularites as would reasonably be expected within the Earth but it also shows that the gravitational gamma factor goes to unity (ie is the same as the gamma factor at infinity) at the centre of the Earth, contradicting what I said in the my last post :(
Mar23-08, 01:26 PM   #11
Quote by kev View Post
I doubt if you can do this, and simply use the outer Schwarzschild solution. I think you have to use the inner Schwarzschild solution (sorry German only):
http://de.wikipedia.org/wiki/Schwarz...re_L.C3.B6sung
Mar23-08, 01:49 PM   #12
A.T.:
The inner solution for r=0 has a non vanishing factor at dt that accounts for the time dilation:
But as far as I know, you have to consider the second derivates of a metric, to tell if it has intrinsic curvature. Curvature is not defined for a dimensionless point, but for an infinitesimal path enclosing an area > 0:
http://en.wikipedia.org/wiki/Introdu...rvature_tensor
Mar23-08, 02:15 PM   #13
Recognitions:
A.T:
The interior solution I've referred to is in Stephani, page 124. He calls it the interior Schwarzschild solution. No doubt different metrics may be found with different assumptions about the energy-momentum tensor.
Mar23-08, 02:27 PM   #14
A.T:
Sure, but as Xeinstein already noted, the space-time line element in the center of a mass>0 cannot be the same as far away in flat space-time. It has to contain the factor of gravitational time dilation.
Aside from that, for the question of space-time curvature at the mass-center: I think that you have to consider how the line element given by the metric changes around that point, by taking the derivates.
Mar23-08, 02:36 PM   #15
A.T.:
I agree. I thought you meant "flat everywhere for r < radius of the sphere, not just at the center. It certainly must be flat there, just by symmetry.
Mar23-08, 04:04 PM   #16
Recognitions:
I must apologise, I misread the print. There is a residual g_tt at r=0. Its value is -
[tex]-\frac{9}{4} (1-Ar_0^2) , A=\frac{1}{3}\kappa\mu c^2[/tex]
Mar23-08, 04:50 PM   #17
Looking at the inner Shwarzchild metric in the link given by A.T. http://de.wikipedia.org/wiki/Schwarz...re_L.C3.B6sung and in this paper http://dbserv.ihep.su/~pubs/prep2005/ps/2005-29e.pdf I get the residual with R=0 as
[tex] dS^2 = \frac{9}{4}\left(\frac{1}{3}-\sqrt{1-\frac{2GM_o}{c^2R_o}}\right)^2c^2dt^2[/tex]
Where [itex]M_o[/itex] and [itex]R_o[/itex] are the mass and radius of the gravitational body and [itex]R_o[/itex] is greater than the Shwarzchild radius of the body.
Does that seem about right? It looks similar to, but not exactly the same as the Mentz formula.
Thread Closed
Thread Tools
Similar Threads for: Classical Gravity versus GR
Thread Forum Replies
what is normally meant by quantizing a classical theory, versus Hardy's axioms Quantum Physics 4
Classical Loop Gravity? Beyond the Standard Model 19
Friction versus Gravity (Work on an Incline) Introductory Physics Homework 2
Applicability of Classical Concepts in Gravity-induced Quantum General Physics 1
interpretations of gravity graviton versus spacetime curvature General Physics 8
