Solving Unusual Log Problem: Find x in ln(x+2)-ln(x+3)+ln(x)=1
  • Thread starter Thread starter The_ArtofScience
    Log
The discussion revolves around solving the equation ln(x+2) - ln(x+3) + ln(x) = 1, which involves logarithmic properties and algebraic manipulation. Participants are exploring various methods to isolate x and simplify the equation, while grappling with the complexities introduced by the natural logarithm and the constant e.
  • Participants discuss different algebraic manipulations, including attempts to rearrange the equation into a quadratic form. Some express confusion over the application of the quadratic formula and the treatment of e as a constant. Others question the validity of their approaches and seek confirmation on their calculations.
The discussion is ongoing, with multiple participants sharing their attempts and reasoning. Some have provided detailed steps in their calculations, while others are questioning the assumptions made in their approaches. There is no explicit consensus on the correct method or solution yet, but various lines of reasoning are being explored.
Participants are navigating the complexities of logarithmic equations and the implications of treating e as a constant. There is also mention of homework constraints and the need for clarity in the steps taken to solve the problem.
The_ArtofScience
Solve for "x" in the equation: ln(x+2)-ln(x+3)+ln(x)=1
This unusual ln problem really has me stumped with what to do and usually this stuff has given me no problems. I can't isolate the x because e is always in the way of solving it. From "ex+3e=x^2+2x" the answer I got was "-2+2(1+3e)^1/2/2e" (?)
e is just a number, so ex+3e=x^2+2x is just a quadratic. put it in the form ax^2 + bx +c and apply the quadratic formula.
I've already done that which simplifies to the answer shown in the first post. I set it equal to ex and then divided by e. I'm not clear as to why it equalled to zero at the end which can't possibly make any physical sense
Another approach I used was to treat 2x-ex as "b" although that produced:
-2-e+(e^2+4+8e)^1/2/2e
That still makes it wrong (ugh)
The answer in your first post is wrong. you'll have to give more details to tell what went wrong. You just want to collect terms with x^2, x and things indendent of x, and then to apply the quadratic formula.
Take ln x to R.HS. and express 1 as 2.303*log10/2.303
simplify.
The quad formula doesn't seem to work in any of the cases and I'm extremely reluctant to change e to its actual irrational form because it'll just get messier.
Physixguru, I'm scratching my head here - where did you get 1= 2.303*log10/2.303?
Kamerling, for the first trial I thought about just isolating the x. So, ex=x^2+2x-3e. Then I tried x^2+2x-ex-3e where b is 2x-ex
Take kammerlings original suggestion again. Treat e like any other constant, pretend you know nothing about its numerical value. You should get [itex]x^2 + (2-e) x - 3e = 0[/itex], a simple quadratic equation.
ln x= 2.303 log x (assuming base 10 )
now 1= 2.303/2.303 ( log 10)
Here is how I did it this time- all the actual steps
-2-e+( (2-e)^2-4(1)(-3e) )^1/2/2
-2-e+( e^2-4e+4+12e )^1/2/2
-2-e+( e^2+8e+4 )^1/2/2
-2-e+( 4(1+2e) )^1/2/2
-2-e+2e(1+2e)^1/2/2
-2+e(1+2e)^1/2/2
Can someone confirm if this is right?
simplify.
None of this makes any sense at all. Apparently "physixguru" is advocating changing to common logs. I have no idea why.
[-(2-e)+/- ( (2-e)^2-4(1)(-3e) )^1/2]/2= [-2+e+/- ( (2-e)^2-4(1)(-3e) )^1/2]/2
better:
[tex]\frac{-(2-e)\pm\sqrt{(2-e)^2- 4(1)(-3e)}}{2}= \frac{-2+e\pm\sqrt{e^2+ 8e+ 4}}{2}[/tex]
Notice the sign difference.
-2-e+2e(1+2e)^1/2/2
-2+e(1+2e)^1/2/2
Thanks HallsofIvy! :-) Made my day as usual
would you like an accurate approach to this problem, ArtofScience?
x = 3.2373049
The answer is quite simple to obtain. You had it right when you stated xˆ2 + 2x = ex + 3e.
Now just set the equation = 0, so xˆ2 + (2-e)x - 3e = 0...
At this point, it's only a matter of graphing it on your calculator or plugging it into the quad form. Either way, you will still obtain the answer of 3.2373049. To check this answer, just plug it back into the original equation for x and be amazed at how it works!
In what sense is that more accurate than the solution ArtofScience gave?
  • · Replies 21 ·
  • · Replies 21 ·
  • · Replies 23 ·
  • · Replies 19 ·
