How can I find a point that is equidistant from two non-parallel lines?
  • Thread starter Thread starter Physicsissuef
    Physics
The discussion revolves around finding a point that is equidistant from two non-parallel lines, specifically the lines defined by the equations x+y-8=0 and x-3y+2=0, as well as a point M(2,8). Participants explore the implications of distance formulas and geometric properties related to these lines and the point.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the use of distance formulas and the concept of equidistance from a point to a line. There are attempts to derive equations for points on the lines and to find relationships between distances. Questions arise about the nature of the distances and whether they are measured perpendicularly.
The discussion is active, with participants providing insights and exploring different interpretations of the problem. Some participants suggest specific points that may satisfy the conditions, while others question the validity of certain calculations and assumptions. There is no explicit consensus on a single approach or solution yet.
Participants note that the lines are not parallel and that the point M(2,8) does not lie on either line, which may influence the conditions for finding equidistant points. There is also mention of the infinite nature of equidistant points from a point to a line, leading to discussions about parabolic relationships.
Physicsissuef
On the straight line x+y-8=0 find point on equal distance of the point M(2,8) and equal distance of x-3y+2=0
[tex]d=\frac{|Ax + By + C|}{|\sqrt{A^2+B^2}|}[/tex]
Should I first find d (distance) from M(2,8) and x+y-8=0?
ok, here it is what i think you need to do: f
the distance among any two points is given with the equation
[tex]d=\sqrt{(x-x_1)^{2}+(y-y_1)^{2}}[/tex]
Let [tex]M'(x',y')[/tex] be a point in the first line, and [tex]M''(x'',y'')[/tex] a point on the second line so from here we get:
[tex]\sqrt{(2-x'')^{2}+(8-y'')^{2}}= d=\sqrt{(2-x')^{2}+(8-y')^{2}}[/tex]
Also use the fact that M', and M'' satisfy the equations of the lines, and see if you can come up with sth.
How to do that?
What exactly is the question? To find a point that is equi-distant from the line x- 3y+ 2= 0 and the point (2, 8)? There are an infinite number of such points: it is well known that the trace of points equidistant from a given point and a given line is a parabola having the given point as focus and the given line as directrix.
Probably the simplest way to find a single such point is to find the midpoint on the line through (2, 8) perpendicular to x- 3y+ 2= 0.
To find an equation for all such points (the equation of the parabola) set the distance from (x,y) to the line equal to the distance from (x,y) to the point equal:
[tex]\frac{x- 3y+ 2}{\sqrt{10}}= \sqrt{(x-2)^2+ (y-8)^2}[/tex]
square both sides and simplify
Yes, you're right. I also realized that. Also we don't know if the distance is normal, so we don't know actually if the formula [tex] d=\frac{|Ax + By + C|}{|\sqrt{A^2+B^2}|}[/tex] does imply... I found one point M(3,5)
"We" don't? Distance from a point to a line (in fact, distance from anything to a line) is always the "shortest" distance and so is always measured perpendicular to the line.
Oh wait, for the first time I notice the part "On the straight line x+y-8=0"! There are either one or two points on that line that cross the parabola of points equidistant to the line and point. Your point (3, 5) satifies that x+ y- 8= 0.
Now, let's see- the distance from (3, 5) to the line x- 3y+ 2= 0 is, according to your formula
[tex]\frac{|3- 3(5)- 9|}{\sqrt{2}}= \frac{3}{\sqrt{2}}[/tex]
The distance from (3, 5) to (2, 8) is [itex]\sqrt{(3-2)^2+ (5-8)^2}= \sqrt{1+ 9}= \sqrt{10}[/itex]. Those don't see to be the same to me.
you're wrong.
It should be
[tex] \frac{|3- 3(5)+2|}{\sqrt{10}}= \sqrt{10}[/tex]
Ooops:redface:!
Physicsissuef said:
How to do that?
Well, when i look a lill bit closer to this problem, i think that it becomes much simpler this way, since you are required to find any point, regardless of what that is. There might be others also that fullfill that condition, but defenitely this will be one.
So we have two lines
[tex]L_1:x+y-8=0, \ \ \ \ and \ \ \ \ L_2:x-3y+2=0[/tex]
Now: [tex]L_1:y=-x+8, \ \\ \ and \ \ \ L_2:y=\frac{1}{3}x+\frac{2}{3}[/tex]
Since we are on the plane, and also since these two lines obviously are not parallel, then they must intersect each other, and this way have a common point, call it K(x',y'). Indeed, this point will be on two lines, and also will be of equal distance from any point and also from your point M(2,8).
So it is sufficient to find the point where these two lines intersect. By solving these eq. we get
[tex]4y-10=0=>y=\frac{5}{2}[/tex] and [tex]x=8-y=>x=8-\frac{5}{2}=\frac{11}{2}[/tex]
So, [tex]K(\frac{11}{2},\frac{5}{2})\right)[/tex] is a point in two lines that is of equal distance from your point.
Well, we have to observe one more thing here, which actually makes all this be true, that M(2,8) does not lie in any of those two lines.
  • · Replies 20 ·
