A question about sorts of using exception
  • Thread starter Thread starter transgalactic
The discussion revolves around different methods of handling exceptions in Java, particularly focusing on the use of "try/catch" blocks and the "throws" keyword in method signatures. Participants explore the implications of these approaches and seek clarification on their usage.
  • One participant mentions familiarity only with the "try/catch" method for handling exceptions and questions the purpose of the "throws" keyword in method signatures.
  • Another participant explains that in many programming languages, including C#, one can catch a general exception without specifying its type, allowing for flexibility in handling errors.
  • A participant clarifies that in Java, all exceptions derive from the Exception class, allowing for a catch-all approach to exception handling.
  • There is a discussion about the "throws" keyword, with one participant noting that it allows a method to indicate it may throw an exception without handling it directly.
  • Another participant raises a question about the absence of catch blocks in implementations that use "throws," seeking clarification on how exceptions are managed in such cases.
  • One participant emphasizes that only classes extending Exception should be thrown, suggesting a structured approach to exception handling.
  • A later reply explains that using "throws" delegates the responsibility of handling exceptions to the method's caller, which can lead to different handling strategies.
Participants express varying levels of understanding regarding the use of "throws" and the implications of not handling exceptions directly within a method. There is no consensus on the best practices for exception handling, and multiple viewpoints on the topic remain present.
Some participants may be operating under different assumptions about exception handling in various programming languages, leading to potential misunderstandings. The discussion does not resolve the nuances of when to use "try/catch" versus "throws" in Java.
transgalactic
i know only the try catch method
that says
for that king of excepion do this
but i saw some weird other implementation
like in the signature of the method "throws exception"
ok now what? it doesn't say what to do in a case of an exception
it just say "throws exception"
what other sorts of exception implementation are there??
Technology news on Phys.org
I'm having a hard time understanding your question.
You don't need (in most languages anyway) to catch a specific type of exception.
Code:
try { int a = 1 / 0; }
catch (DivisionByZeroException e) { Console.Out.WriteLine("Division by Zero"); }
vs
Code:
catch (Exception e) { Console.Out.WriteLine("Something bad happened"); }
(This is c#, your exact vocabulary may vary).
If you catch an unspecified exception, it is sort of up to you what you want to do about it. It depends on the situation. Sometimes you might want to just fail silently (if say your program is checking for updates of itself and can't connect to the server), sometimes you want to display the details of the exception to the user (for most errors) and leave "what to do next" to him or her, and sometimes you want to shut down completely.
k
i forgot to mention that this is java
can you answer this question for JAVA
In java, all exceptions inherit from the Exception class, so you can catch that one if you don't know what you are looking for.
Code:
try
catch (Exception e)
    System.err.println("Error :" + e.getMessage());
k
ye but that's not the only sort
there is the case of a method throws exception
were is the catch stuff there
cause i saw implementation without any catch in this sort of implementation
Are you saying that you throw classes that don't derive from the Exception class? In that case you'd have to know what to catch since you wrote the code. But in general you should only throw Exceptions; you should add "extends Exception" to any class you're throwing. (N.B.: not to any class that throws exceptions, only classes that are themselves exceptions!)
In Java, when you're calling any methods that may throw a given exception, then your options are to use a try/catch to handle the exception or to mark your current method as able-to-throw that exception (using "throws").
This ensures that, even though you're choosing not to handle a given exception in your code, the code that is calling your method will handle that exception itself (or its caller, etc). You use "throws" to delegate the handling of the exception to the caller.
  • · Replies 35 ·
  • · Replies 22 ·
  • · Replies 19 ·
  • · Replies 23 ·
