Calculating Photon Detection in Radiation Physics with 30 Degree Incident Angle
  • Thread starter Thread starter _Andreas
    Physics Radiation
The discussion focuses on calculating the number of photons detected after passing through a 2 mm thick copper plate at a 30-degree incident angle. The formula used for calculating the number of detected photons is N = N0 * e^(mu * L'), where L' is the effective path length adjusted for the angle of incidence. For a 30-degree angle, the path length is determined to be 4 mm, calculated as L' = 2 mm / sin(30). This adjustment is crucial for accurate photon detection calculations in radiation physics.
  • Understanding of linear attenuation coefficients in radiation physics
  • Familiarity with exponential decay formulas
  • Knowledge of trigonometric functions, specifically sine
  • Basic principles of photon interactions with matter
  • Research the linear attenuation coefficient for copper at 100 keV
  • Study the effects of varying incident angles on photon detection
  • Learn about advanced radiation detection techniques and equipment
  • Explore the implications of photon energy on attenuation in different materials
Physicists, radiation safety professionals, and students studying radiation interactions and detection methods in materials science.
_Andreas
The problem: 1000 photons all having an energy of 100 keV hits a copper plate 2 mm thick. How many of these photons can be detected on the other side by a detector that absorbs all radiation? The incident angle is 30 degrees with respect to the plane of the copper plate.
If the angle had been 90 degrees I would have had no problem calculating this -- it would just have been N = N0*e^(mu*L), where N0 is the number of incoming photons, mu the linear attenuation coefficient, and L the thickness of the copper plate. But now that it says 30 degrees, I'm out of ideas.
The path length is greater since the beam is not striking the face at 90 degress, just figure out the correct path length through the 2mm thick slab.
Thanks. I forgot that the photons are assumed either to be absorbed fully by the material, or to pass through without any interaction. So L should be be replaced by L'=4 mm, right? (That is, L'= 2mm/sin30).
  • · Replies 20 ·
  • · Replies 24 ·
  • · Replies 24 ·
  • · Replies 0 ·
