Thread Closed
[SOLVED] Beam Deflection in a Television Tube
Share Thread Thread Tools
Mar26-08, 08:41 PM   #1
Each of the electrons in the beam of a television tube has a kinetic energy of 10.8 keV. The tube is oriented so that the electrons move horizontally from geomagnetic south to geomagnetic north. The vertical component of Earth's magnetic field points down and has a magnitude of 55.0 µT.
How far will the beam deflect in moving 36.0 cm through the television tube?
2. Relevant equations
F=Bqv
F=ma
K=.5mv^2
d=vi*t + .5at^2 ???
3. The attempt at a solution
I've already completed the first two parts of the problem:
(a) In what direction will the beam deflect? East
(b) What is the acceleration of a single electron due to the magnetic field? 5.949657e14 m/s^2
I'm honestly not sure how to calculate the deflection...do I use kinematic equations? Thanks for any tips you can provide!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Mar26-08, 08:54 PM   #2
Figure out the time it takes to reach the end of the tube, and using this time and your acceleration that you calculated, you can find the deflection using kinematics.
Mar26-08, 10:35 PM   #3
Doh! I knew I was overlooking something small. Had to use k=.5mv^2 for the first part to determine the velocity then plug the velocity and displacement in to find the time. Once I found the time, I used the acceleration calculated earlier and found the displacement. Simple! Thanks!
Thread Closed
Thread Tools
Similar Threads for: [SOLVED] Beam Deflection in a Television Tube
Thread Forum Replies
Electron deflection in a cathode ray tube Introductory Physics Homework 7
[SOLVED] Deflection of beam due to magnetic field Introductory Physics Homework 9
Dissecting a cathode ray tube television Computing & Technology 17
Electrons in television tube Advanced Physics Homework 4
I-Beam deflection Mechanical Engineering 6
