Washing Clothes: Mechanical vs Lazy Processes
  • Thread starter Thread starter tgt
The discussion revolves around the differences between washing clothes in a washing machine versus using manual methods such as soaking in a tub with water and detergent. Participants explore the effectiveness, convenience, and labor involved in both approaches, considering various factors like water temperature and the nature of the clothes being washed.
  • Some participants suggest that washing machines are more convenient and effective than manual soaking methods, while others argue that hand-washing can be sufficient for lightly soiled clothes.
  • There is a discussion about the necessity of agitation in washing clothes, with some stating that simply soaking does not adequately remove dirt.
  • Participants mention the labor involved in rinsing clothes when hand-washing, with some expressing that it can be tedious compared to the ease of using a washing machine.
  • Some participants highlight the importance of water temperature, noting that hot water can be beneficial for greasy stains but may also set certain stains or cause fading.
  • There are references to historical washing methods, such as using washboards and ringer machines, indicating that manual washing has been a common practice before the advent of washing machines.
  • One participant shares a personal anecdote about washing clothes without a machine, indicating that alternatives exist for those without access to modern appliances.
Participants express a mix of opinions, with no clear consensus on whether washing machines are superior to manual methods. Some agree on the convenience of machines, while others emphasize the effectiveness of manual techniques, leading to an unresolved discussion.
Participants note various assumptions, such as the type of dirt on clothes and the specific washing methods employed. The discussion does not resolve the effectiveness of soaking versus mechanical agitation, leaving the comparison open to interpretation.
This discussion may be of interest to individuals exploring laundry techniques, those considering the efficiency of washing methods, or anyone interested in historical practices related to clothing care.
tgt
What's the difference between washing clothes in a washing machine and
Filling the tub with water, clothes and powder. Soak it for an hour or so. Drain then repeat again.
Or other lazy, non mechanical process? If so what process?
Assuming clothes that aren't too dirty and with no special treatment like delicate material or colours or anything.
With the method I described, if I used hot water compared to only using cold water in a washing machine, would it turn out better then the washing machine?
Not much difference really, other than it being a lot easier to just throw the clothes in a washing machine than to spend time hand-washing. I find it hard work to get the soap out (you need to rinse the clothes quite a few times) but I only really handwash when I've got, say, one white shirt to wash, or something like that.
Washing machines don't use cold water (unless you put the setting to "cold"). They have different settings and different temperatures for each setting.
We don't use the washing machine even though we have.
You'll never get your clothes clean just getting them wet. You need a washboard and then you, "Plunge, and scrub! Plunge, and scrub! Plunge, and scrub!" Haven't you ever seen the movie "Far and Away"? They give directions.
I wasn't even thinking of rubbing the clothes. Just let them float in soap water. But rinsing them would need some labour?
I know. I was just assuming it to make the comarison.
why not?
So soaking them in soap water don't work? Why not? What if it's only sweat and no dirt or anything like that?
tgt said:
why not?
The washing machine is not good at washing clothes! My hands does.
I wash some things by hand, but everyday stuff goes into the machine, which is much faster/easier.
You're not doing anything to actually get the dirt out. The washing machine agitates to perform this function. You'd have to pretty vigorously stir your clothes to really do a good job, which is really a lot easier if you're just washing them one at a time. The washing machine let's you do them all at once instead of one item at a time.
Nothing except the washing machine will generally make a better job of it, unless your willing to stir the clothes around a bit occasionally, making the same sort of noises your washing machine makes.
However that said if you have delicates silks, satins and woollens of extreme delicacy it can short of dry cleaning be the only way to wash them.
My granny had a copper wash pot, and a giant stick to stir the wash with. It was labor intensive.
I do not have a washing machine so i either take my clothes to moms to wash or i put them in the bath and stomp them, i put my dripping wet shirts on clothes hangers to dry outside
so i do not need to iron them.
I find this is a good way to soften toe nails and makes them much easier to cut.
Nothing really. With the exception of scrubbing, that's exactly how clothes were washed before the creation of washing machines. I know quite a few people who wash their clothes in the bath tub because it saves a significant amount of money since apartments generally do not have washing machines. You can either pay $5 to wash your clothes, or you can stop being a lazy ******* and just do it in the tub.
Your washing machine can consume up to 25% of your electrical consumption for your house. Your TV by comparison is much less, less even than your Kettle or percolator. By comparison light bulbs barely register.
The soap will do less for you than plunging and scrubbing. Soap does break down a lot of types of dirt and grease, making it easier to be washed out by the agitation of the water, but the agitation of the water through the clothes is much more important.
Which begs the question of why you had grease on your pants to begin with.
So if no scrubbing then washing machine is a must?
A washing machine is not a "must", it is a convenient, quick and effective way to clean clothes.
If you watch people in some third world countries washing clothes in the river, they beat the clothes with rocks.
As Bob said a washboard (a board with ridges) was used for a long time to scrub clothes on to get rid of dirt. You would then put the soapy clothes through a ringer to squeeze as much soapy water out as possible before you start to rinse, then run the rinsed clothes through the ringer again to get as much water out as possible so that they dry quicker.
Hot water is good for greasy stains, but can actually cause some stains to "set" and become permanent. Hot water also causes clothes to fade faster.
Some delicate "hand washables" call for only gentle squeezing in warm soapy water, and no wringing or pulling.
In other words, read the clothing labels that tell you how to launder each item.
Not really...being anything from a sloppy eater of fried food to a car mechanic is going to get grease on your clothes.
A separate but related and more specific question, how would you wash a sleeping bag? It says not to wash in a washing machine.
What do the washing instructions say to do?
I use a liner in my sleeping bag. It's like a sheet - easily washable, so I don't have to wash the bag so often.
I used to the say the same about a dishwasher, until I got one, minimum wage immigrant, couldn't do without the staff, one does value ones free time. :smile:
I don't think many people are going to spend their time washing by hand when they can either, pop down to the local launderette or use a washing machine. They may not be essential but they are indispensable once you've got one.
Next you'll be saying TV is not a must, and then I will really have to say steady on!
It just says warm hand wash. So just a bit of rubbing?
BobG said:
If God meant for man to count higher than 1,048,575 he would have given him more fingers and toes.
Offtopic, but what does this quote mean exactly? Why that number specifically?
Yeah, but Bob's is on the inside. Leftovers, perhaps?
Well to cut the drain time out of the whole pic, you would have to place each piece folded on top of one another then put into a box that press'es them, then shoots water and soup through them back and forth over and over again till all the dirt is gone, wouldn't need to spin, just flushes out all the dirt and germ's, until the water quality is fair, then it stop's. And then blows hot air into it, then steam's it, and they come out with no wrinkly's dirt, or germ's. It would look like a Big box. and in side would be a lot of small hole's that suck and blow jets of water and soup, and then hole's that only open when its time to dry and steam.
All you would have to do is fold them before puting them in.
Or we can just pick from hand washing, scrub board, or a washing mach, to do it.
there isn't much things that can replace the effectiveness of a washing mach.
Wouldn't that make it a leftunder?
  • · Replies 19 ·
11K
  • · Replies 21 ·
  • · Replies 18 ·
10K
