Would Hitting a Micro Black Hole with Your Hand Create a Hole?
The discussion centers on the hypothetical scenario of hitting a micro black hole with one's hand, specifically one with a radius of 1/1000th of 1 micron, which would possess a mass of approximately 6.73x10^14 tonnes. Participants concluded that such a black hole would either create an imperceptible hole or result in being sucked into it, with the latter being more likely due to the immense gravitational pull. Additionally, micro black holes are expected to evaporate quickly, meaning they would either be lethal or harmless, depending on their size at the moment of interaction. The acceleration experienced from such a black hole would be around 45000 kilometers per second, vastly exceeding normal gravitational forces.
  • Understanding of black hole physics and Hawking radiation
  • Familiarity with concepts of mass and gravitational forces
  • Knowledge of particle sizes, specifically microns and their relevance in biology
  • Basic grasp of astrophysics and the implications of extreme gravitational fields
  • Research the properties of micro black holes and their formation mechanisms
  • Study Hawking radiation and its implications for black hole evaporation
  • Explore the effects of extreme gravitational forces on matter
  • Investigate the relationship between particle size and biological impact
Astrophysicists, science educators, and anyone interested in theoretical physics and the implications of black holes on matter and gravity.
Denton
In the air, and I tried hitting it with my hand, would I now have a hole there?
You have holes in your hand anyway. If you look closely enough.
I guess you are thinking of a somewhat larger micro black hole?
How about one which has a radius of 1/1000th of 1 micron? Then you would have a mass of approximately 6.73x10^14 tonnes right by your hand. If so, you will have more problems than a little hole in your hand.
By the way, hypodermic needles come in different gauges, the smallest mentioned on wikipedia is a #33, which is 203 microns in diameter, which is about 30000 times bigger than the mini black hole we discussed above. Human cells are typically about 1 micron wide (yes, I know nerves are single cells and very big in comparison, sheesh, I said "typically").
So, you will either have a hole you would never notice or be sucked into the black hole.
Except that mini (micro) black holes are expected to evaporate pretty quickly (if Hawking is right) and the smaller they are the quicker they evaporate, so I am pretty sure you end up with black holes large enough to kill you (making the hole in your hand somewhat irrelevant) or small enough to evapourate before doing you any damage whatsoever.
cheers,
neopolitan
PS - if your hand was held one metre from the centre of your body, you will experience an acceleration due to a black hole of the dimensions discussed above in the order of 45000 kilometers per second. This is about 4.5 million times what you experience due to gravity. That is "bad".
  • · Replies 31 ·
  • · Replies 22 ·
  • · Replies 22 ·
  • · Replies 67 ·
  • · Replies 29 ·
  • · Replies 51 ·
