Linear Velocity and Acceleration
The discussion focuses on the concepts of linear velocity and acceleration in the context of rotational motion, specifically addressing tangential and radial (centripetal) acceleration. It is established that for an object rotating about a fixed axis, both tangential and radial accelerations can exist simultaneously. The actual acceleration of the object can be calculated using the formula a = √(a²_c + a²_t), where a_c is centripetal acceleration and a_t is tangential acceleration, as they form a right angle. The discussion clarifies that tangential acceleration occurs only when the rotation is speeding up, while centripetal acceleration is always present during circular motion.
  • Understanding of rotational motion concepts
  • Familiarity with tangential and centripetal acceleration
  • Knowledge of the formula for calculating resultant acceleration
  • Basic grasp of angular velocity and its implications
  • Study the relationship between angular velocity and linear velocity in circular motion
  • Learn about the effects of angular acceleration on tangential and centripetal acceleration
  • Explore practical applications of rotational dynamics in engineering
  • Investigate the implications of non-uniform circular motion on acceleration
Students studying physics, particularly those focusing on mechanics, as well as educators and professionals involved in engineering and motion analysis.
vladittude0583
Hey guys, we have just finished Chapter 10 (Rotation) and I have some questions regarding some of the concepts. For an object to rotate about some axis, any given particle at point P at some radius "r" has a linear velocity (tangential velocity) and linear acceleration (tangential acceleration). Now, I know that for a particle/object undergoing uniform circular motion, it has a velocity tangential to is radial acceleration. However, how come when you have it rotating about a fixed axis, it has both a tangential acceleration and radial acceleration? Furthermore, they say that the acceleration of the object is the magnitude of both tangential and radial acceleration? Is this magnitude "a" supposed to be the actual acceleration of the particle/object if it was traveling in a linear motion? Or is it because of the fact that a = delta v / delta t?
Thanks.
There is only tangential acceleration if the rotation is speeding up (if there is radial acceleration). However there is always centripetal acceleration if an object is rotating. You can imagine that as a string holding a ball being swung around. The centripetal acceleration is keeping the ball going in a circle. If the string broke suddenly, it would only have a velocity tangential to where it broke.
Now if there is tangential and centripetal acceleration, the actual acceleration of the object is a=[tex]\large\sqrt{a^{2}_{c}+a^{2}_{t}}[/tex]. This is because the tangential and centripetal accelerations form a 90 degree angle. This is the linear acceleration (dv/dt), and the actual acceleration. These things are all different ways of stating the same thing. It is the acceleration of the object.
This wikimedia photo might help conceptually
This is if there is no angular acceleration. That is, tangential velocity is constant and nonzero.
  • · Replies 47 ·
  • · Replies 37 ·
  • · Replies 58 ·
  • · Replies 21 ·
9K
