Thread Closed
Please help with this simple harmonic motion question.
Share Thread Thread Tools
Mar27-08, 12:19 PM   #1
A block rests on a frictionless horizontal surface and is attached to a spring. When set into simple harmonic motion the block oscilates back and forth with an angular frequency of 7.0 rad/sec. The drawing indicated the position of the block when the spring is unstrained x=0. The drawing also show a small bottle located .080m to the right of this position. The block is pulled to the right, stretching the spring by .050m, and is then thrown to the left. In order for the block to knock the bottle over, it must be thrown with a speed exceeding vo (initial velocity). Ignoring the width of the block find vo.
2. Relevant equations
I'm not sure need serious help.
3. The attempt at a solution
w=2pi/x w=.898
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Intel's Haswell to extend battery life, set for Taipei launch
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
Mar27-08, 01:41 PM   #2
Recognitions:
Homework Helper Homework Help
Welcome to PF.
Here is the general approach:
You will need to find the equation of motion. For this, use F = ma.
What is the force? What is the acceleration in terms of the displacement x(t)? This will give you a second order differential equation. What are the boundary conditions? Then find the maximum and solve it for v0.
Just start and show us what you got and where you get stuck, so we can provide more detailed help.
Mar27-08, 04:19 PM   #3
Thank you CompuChip. I don't understand how i'm supposed to find the force since the mass of the block is not given and since I dont know the force I'm not sure how to find the acceleration, and what are boundary conditions? We haven't learned about those in class yet. I mean the only thing the problem provides is the distance the spring travels, and the period while oscilating. Can you jump start me on what equations i need to solve this. Thank you
Mar29-08, 04:12 AM   #4
Recognitions:
You will need the mass, so let's call it m. The force that a spring exerts is [itex]F = - k x[/itex], where k is a constant (it's a property of the string, indicating how easily it stretches and compresses) and x is the displacement from the equilibrium position of the string (if the spring is in equilibrium, there is no force; if you stretch it in one direction, the spring will exert a force the other way to try and restore it to x = 0). This is called Hooke's law.
The acceleration is [itex]a(t) = x''(t)[/itex], the second derivative with respect to time. So if you use Newton's law, you get
[tex]- k x(t) = m x''(t)[/tex]
which is a differential equation for the displacement x(t). Once you solve it, you will get a formula for the displacement x(t). There will be two undetermined constants in there, which you should find. For this you need to use the extra information given: you know what the initial displacement, x(t = 0), and initial velocity x'(t = 0) are. If you plug that into the formula you found, you will get a system of two equations for the two unknown constants, from which you can determine the constants.
Once you have that, you know everything about the motion of the block (it is encoded in x(t)).
Thread Closed
Thread Tools
Similar Threads for: Please help with this simple harmonic motion question.
Thread Forum Replies
Simple harmonic motion question Introductory Physics Homework 4
Question about simple harmonic motion Introductory Physics Homework 3
Simple Harmonic Motion Question Introductory Physics Homework 1
Question regarding simple harmonic motion Introductory Physics Homework 1
Simple Harmonic Motion Question Introductory Physics Homework 3
