Difference between interaction and interference of QM systems
The discussion centers on the distinction between interaction and interference in quantum mechanical systems, specifically regarding entanglement. It is established that entanglement arises from wavefunction interference rather than mere interaction, as demonstrated by the example of an electron-positron pair from a neutral pion decay. The conversation also highlights that while interactions like Coulomb forces exist, they do not inherently create entanglement without the influence of prior coherence. The consensus is that entanglement typically requires a shared history, making the entanglement of particles from separate decays highly improbable.
  • Understanding of quantum mechanics principles, particularly wavefunction behavior
  • Familiarity with tensor product spaces in quantum systems
  • Knowledge of entanglement and its relation to quantum interference
  • Basic concepts of decoherence and its implications in quantum states
  • Study the role of wavefunction interference in quantum entanglement
  • Explore the implications of decoherence in quantum mechanics
  • Investigate the mathematical framework of tensor product spaces in quantum systems
  • Examine case studies of entangled particles and their interactions
Quantum physicists, researchers in quantum mechanics, and students studying the principles of entanglement and interference in quantum systems.
jdstokes
Suppose I have n identical quantum mechanical systems [itex]\mathcal{H}[/itex] isolated from each other. It is a postulate of quantum mechanics that the states of this composite system are described by rays in the tensor product space [itex]\mathcal{H}^{\otimes n}[/itex].
If the states are not allowed to interfere with each other then the state will be a product state of the form [itex]\otimes_{i=1}^n|\alpha_i \rangle[/itex].
Interference between the wavefunctions opens the possibility of entangled states which cannot be factorized into the form above. In this case, the outcomes of measurements on each of the systems can affect the probabilities of the outcomes of measurements on the remaining systems. An example would be the [itex]2^2[/itex] dimensional Hilbert space associated with an electron/positron pair created in the decay of a neutral pion.
Is it correct to say that entanglement is a consequence of wavefunction intereference rather than interaction? In reality the electron/positron pair in the last exam interact via pairwise Coulomb interaction.
Can interactions other than wavefunction interference affect the entanglement between quantum mechanical systems?
If I am not wrong in all cases we know, entanglement(interference) is the result of a common (interacting) past as it is in your case.
So I would put the question this way: If two different pions decay at distant locations. Is it possible that the electron from the first decay can be entangled with the positron from the second decay?
I guess it is not principally impossible but it is extremely unlikely because coherence(interference) is an exceptional case (and can therefore occur only if there is a common past) where decoherence is the more general case.
Am I right?
  • · Replies 61 ·
  • · Replies 44 ·
