Nilpotent Matrix A = {{{021,002,000}}}: What is its index?
  • Thread starter Thread starter Bob Ho
    Index
The discussion revolves around determining the index of a nilpotent matrix A, specifically the matrix A = {{{021,002,000}}}. Participants are exploring the properties of nilpotent matrices and verifying the equation involving the inverse of (I-A).
  • Participants discuss computing successive powers of the matrix A to determine its nilpotency index. There is also a focus on verifying the equation (I-A)^(-1) = I + A + A^2 and the implications of the index on the matrix's properties.
Some participants have confirmed the nilpotency index as 3 after computing A^3 = 0. There is ongoing clarification regarding the verification of the inverse equation and the relationship between the matrix powers and the identity matrix.
Participants are working under the assumption that the matrix is nilpotent and are exploring the implications of this property without providing complete solutions. There is a focus on the algebraic manipulations involved in verifying the properties of the matrix.
Bob Ho
A square(nxn) matrix is called nilpotent of index k if A[tex]\neq[/tex]0, A^2[tex]\neq[/tex]0,...A^(k-1)[tex]\neq[/tex]0, But A^k=0 for some positive integer K
Verify that A={{{021,002,000}}} is nilpotent. What is its index? Show that for this matrix (I-A)-1= I + A + A^2
I am unsure how different values of k affects the matrix... but For the equation (I-A)-1= I + A + A^2, I found the inverse of (I-A) which was {{{125,012,001}}}, which then gave me A^2 as {{{004,000,001}}}.
You got the inverse of (I-A) ok. I'm assuming by A2 you mean A^2 (i.e. A squared, A times A). That didn't come out right. To find the index of A just keep computing successive powers A until you get zero. What is the index? To show (I-A)^(-1)=(I+A+A^2) you just want to show (I-A)*(I+A+A^2)=I. To do that you don't even need the numerical value of A once you've found it's index.
Thanks a lot! I figured out A^3=0 so I am assuming the nilpotent matrix is of index 3.
I'm not sure how you managed to get the equation "(I-A)*(I+A+A^2)=I." I just did I=(I-A)^-1 -A - A^2. Would that also be suitable?
You've got the index too. So A^3=0. If C^(-1)=D then that just means C*D=I. So to check if (I-A)^(-1)=(I+A+A^2) just check whether (I-A)*(I+A+A^2)=I. That's where I got it. To check that just multiply that expression out. Remembering A^3=0.
15K
9K
