Reviewing Algebra for CAT6 Test: 3 Challenging Problems
  • Context: Undergrad
  • Thread starter Thread starter Imparcticle
    Algebra Test
The discussion revolves around reviewing algebra concepts in preparation for a CAT6 test, focusing on three specific problems related to roots and factoring. Participants are examining their solutions and the answers provided in the textbook, highlighting areas of confusion and disagreement.
  • Homework-related
  • Post 1 presents a problem involving roots, where the participant's answer differs from the textbook's answer, leading to a discussion about the application of exponent rules.
  • Post 2 asserts that both the participant and the textbook are incorrect in the first problem, providing a different calculation using the exponent rule for multiplication.
  • For the second problem, Post 2 explains the correct application of the exponent rule for division, arriving at a different answer than the participant's original response.
  • Post 3 challenges the participant's approach to the factoring problem, stating that they cannot factor out (x+16) again after simplification and suggesting a misunderstanding of the distributive property.
  • Post 4 acknowledges the explanation provided and suggests a preference for calculating roots using exponential notation rather than radicals.
  • Post 4 also reflects on the participant's misunderstanding regarding the distribution of terms in the factoring problem.
Participants express disagreement regarding the correctness of the answers to the problems presented. There is no consensus on the solutions, as different interpretations and calculations are discussed.
Participants express uncertainty about the application of algebraic rules, particularly in the context of roots and factoring. There are unresolved aspects regarding the simplification steps and the treatment of like terms.
Imparcticle
I am currently reviewing my whole algebra textbook for a CAT6 test on tuesday. Apparently, it is very difficult, so I'm taking every minute to review.
Anywho, I ran into 3 problems that are currently driving me crazy. :-p
One concerns roots.
Here is the problem the book presents:
(6x2x)x1/2
My answer was (36x3)1/2. But the book says the answer is (6x)5/2
BTW, how do you write root signs using the latex program?
another root problem:
y3/y1/4
My answer was x3/4. The book says x11/4 is the answer.
Now, here is a factoring problem:
-4(x+16)4 + 9(x+16)2 + x + 16
On this problem, the part that confuses me is the answer:
[-4(x+16)3 + 9x + 145) (x+16)
I arrived at this answer on my own, except I went one step further:
when I got to [-4(x+16)3 + 9x + 145) (x+16) , I went ahead and rewrote (x+16)3 as (x+16)(x+16)2 so that I could distribute the -4. I then arrived at (x+16)3 (5x+81). Apparently, my final step was incorrect. I would like to know why.
Also, I did most of these operations in my head (as it is easier for me to do so), so if you would like me to explain anything that I did, I should point out that I may sound unmathematical in a sense.
Thank you for your time.
The book is wrong on the first problem, and so are you. ;) Remember the rule that says [tex]a^xa^y = a^{x + y}[/tex]. This rule works even when x or y are fractions.
[tex](6x^2x)x^{1/2} = (6x^3)x^{1/2} = 6x^3x^{1/2} = 6x^{3 + 1/2} = 6x^{7/2}[/tex]
For the second problem, remember [tex]\frac{a^x}{a^y} = a^{x - y}[/tex], even when x or y are fractions.
[tex]\frac{y^3}{y^{1/4}} = y^{3 - 1/4} = y^{11/4}[/tex]
And the last part on factorization. It's just wrong. You cannot pull a factor of x+16 out of the expression again after you've simplified it once. What do you mean to do in "distributing the -4"? You have done something that is against the laws of arithmetic and algebra, that's all.
Muzza: Thank you for your kind explanation. It seems to me that from now on, it is far more efficient to calculate roots exponentially; without using a radical.
Mattgrime: When I said "distribute the -4", I meant applying the distributive property.
But I see the mistake now. They weren't like terms? (I am referring to the factoring problem)
  • · Replies 44 ·
  • · Replies 18 ·
  • · Replies 25 ·
