Finding the Multiplicity of Eigenvalues for a 2x2 Matrix with a Variable Element
The discussion revolves around finding the conditions under which a 2x2 matrix has a real eigenvalue of multiplicity 2, specifically focusing on the variable element k in the matrix A = |4 k| |-7 -5|.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss setting up the characteristic polynomial using the determinant and explore the implications of the discriminant for the eigenvalues. Questions arise about the conditions needed for the discriminant to yield a double root.
Participants are actively engaging with the mathematical setup and exploring the implications of the discriminant. Some guidance has been offered regarding the need for the discriminant to equal zero for a double root, but there is no explicit consensus on the resolution of the problem.
There are indications of confusion regarding the calculations involving the discriminant and the variable k, with participants questioning the feasibility of achieving the necessary conditions for a double root in the context of the problem.
snoggerT
For which value of k does the matrix
A=
|4 k|
|-7 -5|
have one real eigenvalue of multiplicity 2?
- I tried by setting this problem up with det(A-(lambda)I) and trying to solve like that, but I can't seem to get it that way either. I am getting (lambda)^2+(lambda)-20+7k=0, but I don't know what to do from there. Please help.
Well, what you have there is quadratic equation lambda .. do you know how to solve such an equation (hint; there is a formula ...:smile:)
This formula will give you (in general) two different solutions (which might be complex). However, when you've figured out the formula for the eigenvalues (depending on k) you can think about what k has to be, such that these two eigenvalues are actually the same.
So first you need to find the lambda's which fulfill your equation. And don't worry about k. It's just some constant number.
look at the discriminant
so the discriminant is negative, so that means there are no real roots and k would have to be something that would have the discriminant come out to 1, right? is it even possible to get the discriminant to equal 1 in this situation with b=1? am I not seeing what you all are pointing out?
The discriminant is b^2-4ac. You want it to be zero to get a double root.
in order to get zero you would need the discriminant to come out to 1-1, but I don't know how you would get the 4ac to be equal to 1 with this problem. If you ignore the 7k, the discriminant is 81, but in order for the discriminant to be zero, wouldn't -20+7k have to equal 1/4?
Yes. 7k-20 should equal 1/4. Why is that a problem?
I just made a simple mistake in my math. Thanks for the help.
  • · Replies 19 ·
  • · Replies 18 ·
