When should I use dy/dx versus f'(x) for derivatives?
The discussion revolves around the use of different notations for derivatives, specifically dy/dx versus f'(x). The original poster seeks clarification on when to use each notation as they begin learning about derivatives.
  • Participants explore the equivalence of the notations, with some suggesting that consistency is key. Others discuss preferences for one notation over the other based on context, such as manipulation of derivatives in physics versus mathematics.
There is an ongoing exploration of the notations, with participants sharing their experiences and preferences. Some guidance on maintaining consistency in notation has been offered, but no consensus has been reached on the superiority of one form over the other.
Participants mention specific contexts, such as physics and higher-order derivatives, that may influence the choice of notation. The original poster's lack of access to their textbook adds a layer of uncertainty to their understanding.
dranseth
I cannot seem to find my textbook and we just started derivatives. Can anyone tell me when I would use the notation dy/dx as opposed to something like f'(x)??
Thanks!
f'(x) is just function notation. If you're given an f(x), it's equally correct to use f'(x) or d(f(x))/dx, for example. In the case of f'(x), the derivative with respect to x is implied.
So it wouldn't ever matter which one I use? I could use both?
You should stick with one for consistency. There's nothing wrong with using y' over dy/dx, or f '(x) over d(f(x))/dx; Just be consistent.
Not loosely in a sense.
For example, if you have
[itex]y=x^2[/itex]
You would write [itex]\frac{dy}{dx}[/itex] or [itex]y'[/itex] = [itex]2x[/itex] and NOT [itex]f'(x)=2x[/itex]
The dy/dx notation is nice when you're actually manipulating these as if they're actually numbers. It's a physicist's favorite trick (but a mathematician's worst nightmare). I for one am not a fan of f'(x), except when there are higher order derivatives involved.
I'd get used to both forms, as they seem to turn up alternately, at least in my experience.
For example the quotient rule:
Leibniz notation:
[tex]\frac{d}{dx}\left (\frac{u}{v}\right ) = \frac{\frac{du}{dx}\cdot v-u\cdot\frac{dv}{dx}}{v^2}[/tex]
Newtonian notation:
[tex]h'(x) = \frac{f'(x)g(x) - f(x)g'(x)}{[g(x)]^2}[/tex]
or in shorthand notation:
[tex]h'=\frac {f'\cdot g-f\cdot g'}{g^2}[/tex]
You might see something similar as well which is a Newtonian notation:
[tex]\dot{h}(x)=\dot{f}(x)+\dot{g}(x) \longrightarrow \ddot{h}(x)=\ddot{f}(x)+\ddot{g}(x)[/tex]
or
[tex]h\,\dot{}\,(x)=f\,\dot{}\,(x)+g\,\dot{}\,(x) \longrightarrow h\,\ddot{}\,(x) = f\,\ddot{}\,(x) + g\,\ddot{}\,(x)[/tex]
occasionally but these aren't used very often.
Which is the same as saying:
[tex]\frac{d}{dx}(u + v)=\frac{du}{dx}+\frac{dv}{dx}\longrightarrow \frac{d^2}{dx^2}(u + v)=\frac{d^2u}{dx^2}+\frac{d^2v}{dx^2}[/tex]
in Leibniz notation.
They look more complicated between forms sometimes, but once you get the idea they're pretty obvious.
  • · Replies 25 ·
