Heat Effects on an Aluminum Annular Ring
The discussion revolves around the thermal expansion of an aluminum annular ring, specifically focusing on the behavior of the hole within the ring when subjected to heat. Participants are exploring the implications of thermal expansion on both the material and the hole's dimensions.
  • Participants are examining various statements regarding how the hole's diameter and area change in relation to the aluminum's expansion. There is a consideration of the geometric implications of thermal expansion on the annular shape.
Some participants have expressed their views on the correct answer regarding the expansion of the hole, with one suggesting that the hole expands the same amount as the rest of the aluminum. Others are analyzing the physical structure of the annulus to understand the effects on the hole's circumference and area.
There is a mention of uncertainty regarding the correct answer to the posed question, with one participant explicitly stating that they believe one of the options is incorrect. The discussion reflects a lack of consensus on the interpretation of thermal expansion effects.
Xamfy19
An annular ring of aluminum is cut from an aluminum like attached.
When the ring is heated,
1)the hole decreases in diameter
2)the area of the hole expands the same percent as any area of the aluminum
3)the area of the hole expands a greater percent than any area of the aluminum
4)linear expansion forces the shape of the hole to be slightly ellipitcal
5)the aluminum expands outward and the hole remains the same in size
I know the answer isn't 3), but I didn't get the answer. Thanks.
It's #2; the hole expands same amount as the rest.
Imagine the annulus as composes of many tiny radial rectangles. Consider what happens to all four edges of the rectangles. Consider what that means for the circumference of the hole. Translate that into an effect on the diameter and area of the hole.
Thanks a lot
Thanks for all of you posted the reply.
24K
9K
  • · Replies 24 ·
