| New Reply |
Nuclear Reactor |
Share Thread | Thread Tools |
| Apr1-08, 02:53 AM | #1 |
Nuclear Reactor
This may not be an appropriate place to ask this, and if that is the case please chastise me and cast me out. Given that the members of this forum seem to be very educated and intelligent, especially in regards to these fields I wanted to ask a question. What would be the absolute worst case nuclear reactor meltdown? What sorts of effects could one expect and at what types of distances? And bear in mind, I really am asking about the worst it could possibly get, as in, no one there to SCRAM the control rods, no fire crews responding, that sort of disaster scenario.
| Apr1-08, 07:43 AM | #2 |
Think Chernobyl times ten, but not Hiroshima-Nagasaki. As I understand it, a small explosion is possible, but not kilotons. The big tragedy is a large escape of radioactive by products. You would probably get better answers if this were moved to the Nuclear Engineering forum.
Best, Jim Graber |
| Apr1-08, 08:15 AM | #3 |
But beware: that's not a *meltdown*. It was a blowing up of the reactor by sudden overheating. Also, a nuclear reactor can *never* undergo a nuclear explosion (as in an atomic bomb). It is physically impossible. You can at most have strong heat production which will make the confinement give up under heat and pressure. At Chernobyl, it was the water that got heated too much in the tubes that blew up the reactor structure. A *meltdown* is a much less severe accident, and it doesn't imply necessarily any release of radioactivity to the environment. A meltdown happens when the fuel elements are not cooled enough, so that they reach their melting point - inside the reactor. For instance, a meltdown can happen when there is a loss of coolant, or in a PWR, a loss of pressure, so that the cooling water starts boiling off. This is what happened (by wrong manipulations by the control crew) in the 3-miles island accident: the rods containing the fuel can get so hot as to melt. This can happen even with the reactor shut off (in fact, with a loss of coolant, normally the reactor shuts itself off immediately), but because of the heat of radioactive decay. We are talking here about much lower power productions than the 30 GW that blew up the Chernobyl reactor, but nevertheless they can melt the fuel. The thing to do is to restore the cooling, and the incident is closed (but the reactor is damaged). If the cooling cannot be restored, then things can get worse: the heat can end up damaging the reactor vessel, and as such, the fuel can escape the reactor vessel and arrive in the confinement building. If one still doesn't cool this, the confinement building can end up damaged by the hot fuel, and some fuel can escape to the outside (but not in a plume in the atmosphere!). When spread out enough in the neighbourhood, the fuel will cool down and that's it. This is very heavy, but local, contamination. Again, serious as this is, this is nothing comparable to Chernobyl. In Chernobyl, everything was really put together to make the accident as bad as possible. That's why I cannot imagine anything worse. In fact, in modern reactor design (such as the EPR), a meltdown is considered as a possible accident that should be handled. Hence, there is a cooled "core catcher" underneath the reactor vessel which stops the accident right there, without any release to the outside. This is why even a worst-case accident with a western power plant can never be as severe as the Chernobyl accident (where the reactor was unstoppable because of bad design - they stopped it finally by dumping boron on the carcass with helicopters). So the only driving force for an accident that remains is decay heat, which is far less than the reactor power. |
| Apr1-08, 12:25 PM | #4 |
Nuclear Reactor
So in a scenario where there was aboslutely no one available to man the plant, unexpectedly, (think neutron bomb or the rapture) the plant would still shut down safely by default?
| Apr1-08, 01:33 PM | #5 |
The culprit is the needed electricity for the cooling pumps, which are in case of blackout generated by emergency generators (usually redundant diesel engines). If they run out of fuel (after days or weeks), there can be a problem with the cooling (of the residual heat of radioactive decay). Now, I think (but I'm not sure) that at least the primary water circuit of a modern PWR is designed such that pure passive convection is sufficient to bring the decay heat to the steam generators without the primary pumps activated. However, there needs to be secondary water cooling to evacuate the heat from the steam generators - I don't think things have been designed completely passively there (although that is in principle possible but cumbersome). That said, a nuclear power plant can also work "independently" loose from the main grid, at low power, and provide itself with electricity - the reactor is now active, but at something like 10% of its nominal power. In this mode, a power plant can run a very long time "all by itself". However, I think it needs manual control in this mode. |
| Apr1-08, 01:41 PM | #6 |
There are just too many variables to have a reasonable answer to that. Plants require people to run them (top up gasses, maintain chemistry etc) but safety systems are designed to put the plant in a safe state when certain parameters are out of norm, so it would self scram. Assuming a normal scram, I think the plant would be just fine for quite a long while due to the engineered design features. But since there are lots (understatement) of people that work at nukes, it's just not something that is very probable. |
| Apr2-08, 01:02 AM | #7 |
A point that has been implied but not mentioned specifically is that it depends on the design of the particular plant. In general, older designs are less safe and newer ones more safe. So called third and fourth generation designs are intended to "self shut down" in essentially the way you mention. In fact, some experts who know more than I do claim that even an incident as bad as Chernobyl is impossible or highly unlikely for second generation designs such as most of those now operating in western countries.
Of course, you can think of worse scenarios, like dropping a real nuke on a reactor, or just a deliberately dirty bomb... Best, Jim Graber |
| Apr2-08, 01:47 PM | #8 |
I ask these questions because I am a writer. In al my work I try to strive for as much realism as possible, within the confines of the fantastic situations I create. The particular tale which gives rise to this question centers around a zombie plague and the attempts to contain and correct it. Basically, I am just looking for the worst case scenario so I can make sure to not go overboard in my depiction of a reactor event.
| Apr3-08, 03:04 AM | #9 |
| Apr3-08, 05:51 PM | #10 |
A zombie plague hits the plant around 4 in the morning most nights, but it seems to be mostly giddy zombies that don't make much sense when talking.
| Apr3-08, 06:58 PM | #11 |
Edit: I see after reading more above that this was only possible w/ the earlier reactor designs. |
| Apr4-08, 03:05 AM | #12 |
| Apr16-11, 01:23 PM | #13 |
Well. We have 2 reactors that have totally melted down in Japan. What I'd like to know is what the consequences of that is.........i.e. Now what? What will happen now that you have molten pools of radioactive material at the bottom of the containment vessels........with no carbon rods slowing down the reaction? PS. I think it's time for the cement trucks.....................and bury all that stuff........ z |
| Apr16-11, 01:29 PM | #14 |
Worstcase in slow neutron reactor: have the fuel cook itself with decay heat in a pressure vessel that has water on outside but is missing the lid (or is vented very effectively). Do nothing. Let the fuel temperatures in the middle reach boiling, liberating so many various isotopes with various nasty behaviours (Sr-90 for one thing) that you'll stop thinking that Chernobyl was a worst case. This corium won't melt through the pot because of low thermal conductivity of corium and cooling on outside. For more lulz, as the last thing, let water level outside the vessel drop , so that the vessel melts and it falls into water, resulting in a steam explosion that spreads the **** all over the place, and turns a lot of molten corium into aerosol. For even more lulz, have it happen at 4 or more reactors with 4 spent fuel pools each storing 3x the core load, re-racked for max density, and let the spent fuel run dry and catch fire. For even more lulz, build a lot of powerplants on a coast all to same standards, and have several of them suffer this at once as you are hit by the tsunami.
also: Chernobyl's criticality ceased when it explosively disassembled. Worstcase in fast neutron reactor (highly enriched fuel): steam explosion in one part of the core compressing rest of the core, resulting in low power nuclear kaboom that'd vaporize the core. Have it happen as close to the end of fuel cycle as possible. Face it, neither Chernobyl nor Fukushima are as bad as it can be. Chernobyl barely released anything besides noble gasses, caesium, and iodine. Just the stuff that easily leaves fuel. It wasn't burning very hot. |
| Apr16-11, 01:37 PM | #15 |
Well.......the water table can't be that deep there.......when it hits it......will get a lot of radioactive steam coming up right?
| Apr16-11, 01:38 PM | #16 |
Yeah....people keep comparing this with Chernobyl........down the road aways, when the next one happens, they'll be comparing it with Fukushima.......lol.........z
| Apr16-11, 01:41 PM | #17 |
| New Reply |
| Thread Tools | |
Similar Threads for: Nuclear Reactor
| Is there another way for nuclear reactor? | High Energy, Nuclear, Particle Physics | 2 | ||
| U237 in nuclear reactor? | General Physics | 1 | ||
| nuclear reactor | High Energy, Nuclear, Particle Physics | 8 | ||
| Numerical Nuclear Reactor | Nuclear Engineering | 18 | ||
| Is A Nuclear Reactor A...... | Mechanical Engineering | 15 | ||
