Cat urine in pool chemical room
  • Thread starter Thread starter assembler
    Chemical
The discussion revolves around concerns regarding the potential chemical reactions between cat urine and pool chemicals, specifically chlorine, in a basement pool equipment room. Participants explore the implications of these interactions, safety measures, and general handling of pool chemicals.
  • One participant expresses concern that cat urine could mix with chlorine and create a toxic gas, questioning the safety of the situation.
  • Another participant suggests that the ammonia content in cat urine is likely insufficient to pose a significant problem, recommending proper ventilation and cleanup.
  • A different viewpoint proposes simply locking the cat out of the room as a preventive measure.
  • One participant emphasizes that the release of chlorine gas during the refilling of the chlorinator may be a greater concern than the urine itself, advocating for the installation of a vent fan.
  • Another participant stresses the importance of keeping pool chemicals secured and handling them with caution to prevent hazardous situations.
  • A later reply humorously notes the absence of the original poster, implying a negative outcome from the situation.
Participants do not reach a consensus on the level of risk posed by the cat urine in relation to the pool chemicals. Multiple competing views remain regarding the safety and necessary precautions.
Participants mention various safety measures and concerns, but there is no agreement on the specific chemical interactions or the extent of the risk involved. The discussion reflects a range of assumptions about chemical behavior and safety practices.
assembler
Discovered that my cat has been urinating in my pool equipment room this winter. My equipment room is in my basement. We store all of our pool chemicals here. I am worried that the chlorine will mix with the urine and create a toxic gas. Could this happen? Sometimes when my husband refills our chlorinator there is a stong odor given off.
Chemistry news on Phys.org
Shouldn't be enough ammonia in the cat urine to be a problem. Just vent the room well as and after you clean up. Which, really, you should be doing for anywhere you store chlorine at anyway.
You could try locking your cat out of the room.
Just a thought.
Rinse the urine spots with some vinegar and then with water.
I would think the simple chlorine gas escaping as you're pouring the chemicals into the water would be more of a concern than the small amount of reactant from the urine. You should install a good vent fan into that room to ensure none of those chemicals are accumulating in the air you're breathing. None of that is healthy in enclosed spaces (the whole point of using chlorine in the pool is to KILL stuff...enough of it will kill you too).
Always keep swimming pool chemicals out of the reach of children and pets. You should place your pool chemicals in a locked room or closet. It is very hazardous. Close the pool chemical containers tightly because it gives off harmful gas. Use mask and gloves when handling chemicals. And never mix them to other chemicals because it can explode and cause fire.
Assembler went dark after her first post two years ago. Pity that you didn't come by sooner.
We all expect that the worst has happened... BOOM!
  • · Replies 19 ·
11K
  • · Replies 68 ·
406K
  • · Replies 43 ·
14K
  • · Replies 20 ·
  • · Replies 39 ·
18K
