Phase Transition: Determine Order of Transitions
The order of phase transitions is determined by analyzing the continuity of the Gibbs function. A first-order transition occurs when the Gibbs function is continuous, but its slope is discontinuous, typically due to latent heat, such as in melting. In contrast, a second-order transition is characterized by both the Gibbs function and its first derivative being continuous, while the second derivative is discontinuous. The conductor-superconductor transition in liquid helium is noted as a known example of a second-order transition. Additionally, the 'lambda transition' involves diverging thermodynamic properties, leading to the development of renormalization and scaling concepts.
  • Understanding of Gibbs function and its derivatives
  • Familiarity with first-order and second-order phase transitions
  • Knowledge of thermodynamic properties such as specific heat
  • Basic concepts of renormalization and scaling in physics
  • Research the properties of the Gibbs function in thermodynamics
  • Study examples of first-order and second-order phase transitions
  • Explore the lambda transition and its implications in statistical mechanics
  • Investigate recent advancements in phase transition theories over the last decade
Physicists, thermodynamic researchers, and students studying phase transitions and their implications in material science and statistical mechanics.
j-lee00
How does one determine the order of phase transitions?
Science news on Phys.org
By the degree of continuity in the Gibbs function. If the Gibbs function is continuous, but its slope is discontinuous (say due to the latent heat of melting), the transition is first-order. If both the Gibbs function and it's derivative is continuous, but the second derivative is discontinuous, the phase change is a second-order. AFAIK, the conductor-superconductor transition in liquid He is the only known second-order transition, but I don't have any really up-to-date references.
There's also a 'lambda transition', in which some of the thermodynamics properties (specific heat, for example) diverges. The resolution of that led to renormalization and scaling concepts.
The concept of a phase transition has really expanded over the past 10 years or so- some of what I wrote may be out of date.
  • · Replies 78 ·
  • · Replies 29 ·
