Can Multi-Layered Buckyonions Enhance Beta-Decay Rates?
  • Context: Graduate
  • Thread starter Thread starter sanman
The discussion centers on the potential enhancement of beta-decay rates using multi-layered buckyonions, inspired by research from Professor Ohtsuki in Japan. It proposes that radial polarization of the buckyonion, possibly achieved by surrounding it with anions, could increase electron charge density towards the interior. The concept of hydraulic compression is introduced, suggesting that the larger outer surface area of the buckyonion could concentrate force onto the smaller inner area, potentially accelerating beta-decay further. However, it is noted that producing a uniform electric field to push electrons inward is not feasible due to the shell theorem.
  • Understanding of beta-decay processes in nuclear physics
  • Familiarity with C60 buckyball fullerenes and their properties
  • Knowledge of radial polarization and electric fields
  • Concepts of hydraulic compression and its applications
  • Research the effects of high pressure on molecular structures, particularly buckyballs
  • Explore the principles of radial polarization in charged particles
  • Investigate the implications of the shell theorem in electrostatics
  • Examine experimental methods for enhancing beta-decay rates in controlled environments
Physicists, materials scientists, and researchers interested in nuclear decay processes and the manipulation of molecular structures for enhanced particle interactions.
sanman
I'd read about some research by a Professor Ohtsuki in Japan, where he'd found that an atom will undergo accelerated beta-decay when trapped inside a C60 buckyball fullerene.
So I wanted to ask if the effect could be enhanced still further using a multi-layered buckyonion. I was wondering if the buckyonion could be polarized in a radial direction, to build up higher electron charge density towards its interior. Perhaps that polarization could be caused by surrounding the buckyonion with anions, for example. Anyway, I was thinking that as the electrons from each layer crowd inwards towards the layer below, that this could end up creating a "hydraulic compression" effect (ie. a hydraulic piston works by taking force applied across a wider surface area and concentrating it onto a smaller surface area). The idea would be that the surface area on the outside of the buckyonion is significantly greater than the surface area on the inside of the buckyonion, so that the radial polarization would concentrate force against the smaller interior.
I was thinking that this could then enhance the beta-decay rate still more.
Comments?
You can't produce an electric field that pushes electrons towards the center everywhere. This is a result of the shell theorem.
You could put the whole thing under high pressure, compressing the whole buckyball a bit.
9K
  • · Replies 21 ·
13K
11K
