Why is the 3 momentum represented with a negative sign in the 4-vector?
  • Context: Graduate
  • Thread starter Thread starter Davio
    Momentum
The discussion revolves around the concept of 3-momentum and its relationship to 4-momentum in the context of physics, particularly in special relativity. Participants explore the definitions, mathematical representations, and implications of these concepts, including the significance of the negative sign in the 4-vector formulation.
  • Some participants define 3-momentum as a vector containing the components \(p_x\), \(p_y\), and \(p_z\), which represent the spatial part of the 4-momentum.
  • One participant describes the mathematical relationship between 3-momentum and 4-momentum, emphasizing that 3-momentum is derived from the spatial components of the 4-momentum vector.
  • Another participant discusses the geometric interpretation of momentum in a 3D reference frame, using the Pythagorean theorem to relate spatial and temporal components.
  • There is a question regarding the representation of the temporal component in the 4-momentum, specifically why it is negative, with some suggesting it relates to the invariance of the 4-vector magnitude across different inertial frames.
  • One participant notes that the negative sign ensures the magnitude of a 4-vector remains invariant, while a positive sign would not maintain this invariance.
Participants generally agree on the definition of 3-momentum as the spatial part of 4-momentum, but there is ongoing debate regarding the implications of the negative sign in the 4-vector formulation and its significance in maintaining invariance. The discussion remains unresolved on the deeper implications of these mathematical representations.
Some participants express uncertainty about the mathematical steps involved in deriving the relationships between 3-momentum and 4-momentum, particularly regarding the treatment of the temporal component and its sign. There are also references to different observers determining different 3-momentum vectors from the same 4-momentum vector.
Davio
Hey guys, what exactly is a 3 momentum? I can't any references to it anywhere on the net, which actually tells me what is it, I know a energy 4 momentum is, px , py, pz e/c, but that's not much help!
Three momentum is simply a vector containing all three momenta,
[tex]\boldmath P \unboldmath = \left(\begin{array}{c}p_x \\ p_y \\ p_z\end{array}\right)[/tex]
3-momentum is the "spatial-part" of the 4-momentum.
Here is one place to consult:
http://www2.maths.ox.ac.uk/~nwoodh/sr/
In a 3D reference frame a line of arbitary length and direction from the origin of the frame can be described in terms of x,y and z component. Using pythagorous theorem we can find the length of that arbitary line from [tex]L =\sqrt{x^2+y^2+z^2}[/tex] You could call that length the 3 length sometimes abreviated to ||L||. When we include an additional dimension of time to the 3 spatial dimensions then we have the 4 length [tex]\sqrt{x^2+y^2+z^2-(ct)^2}[/tex]
or [tex]\sqrt{||L||^2-(ct)^2}[/tex]
Similarly 3 velocity ||v|| = [tex]\sqrt{v_x^2+v_y^2+v_z^2}[/tex]
and 3 momentum ||p|| = [tex]\sqrt{p_x^2+p_y^2+p_z^2}[/tex]
(Edited to fix the typo pointed out by ehj)
Shouldn't it be?
ehj said:
Shouldn't it be?
Yes, sorry about the typo. :(
I should clarify that, given a 4-momentum vector,
the 3-momentum is essentially the "spatial-part" according to a given observer.
That is, the 3-momentum is [obtained from] the vector-component of the 4-momentum that
is [Minkowski-]perpendicular to an observer's 4-velocity.
From a given 4-momentum vector, different observers will determine different 3-momentum vectors.
Given a 4-momentum [tex]\tilde p[/tex] and an observer's 4-velocity [tex]\tilde u[/tex] (with [tex]\tilde u \cdot \tilde u=1[/tex] in the [tex]+---[/tex] convention),
Write out this identity [a decomposition of [tex]\tilde p[/tex] into a part parallel to [tex]\tilde u[/tex], and the rest perpendicular to [tex]\tilde u[/tex]]:
[tex]\tilde p = (\tilde p \cdot \tilde u)\tilde u + (\tilde p - (\tilde p \cdot \tilde u)\tilde u)[/tex].
The 4-vector [tex](\tilde p - (\tilde p \cdot \tilde u)\tilde u)[/tex] is "purely spatial" according to the [tex]\tilde u[/tex] observer [check it by dotting with u], and can be thought of as a three-component vector in [tex]\tilde u[/tex]'s "space" by projection. That projected vector is the 3-momentum of the object according to [tex]\tilde u[/tex].
(Note, however, that the 4-vector [tex](\tilde p - (\tilde p \cdot \tilde u)\tilde u)[/tex] is generally NOT "purely spatial" according to another observer [tex]\tilde w[/tex]. To [tex]\tilde w[/tex], that 4-vector has both nonzero spatial- and temporal-parts.)
Hey guys, feel a bit silly, of course its just the partial part! Whilst we're on that topic though, why is it -(ct)^2 and not positive? Is it because CT=Distance, L^2+D^2 =p^2 ? Surely not though because, L ^2 = x^2 +y^2 +z^2
With the "-" sign in that position, the "magnitude" of a 4-vector is invariant between different inertial reference frames. With a "+" sign instead, the "magnitude" is not invariant.
  • · Replies 0 ·
  • · Replies 23 ·
  • · Replies 36 ·
