How to Solve a Differential Equation with Nonlinear Terms?
The discussion revolves around solving a differential equation with nonlinear terms, specifically in the context of the equation xy' = x(e^(-y/x)) + y. Participants express confusion regarding the solution process and the steps involved in manipulating the equation.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss rewriting the equation and consider substitutions, such as y = vx. There is uncertainty about the next steps after substitution and the integration process. Some participants express frustration over not arriving at the expected solution.
Guidance has been offered regarding the differentiation of products and the nature of the substitution. Participants are actively engaging with each other's reasoning and clarifying misunderstandings, though no consensus on the solution has been reached.
There is mention of potential mistakes in taking logarithms and the need for careful differentiation, indicating that participants are grappling with the complexities of the problem. Some express concern about the difficulty level of the question.
sara_87
solve the diffrential equation:
answer:
y = xln|lncx|
problem:
i don't get it
can anyone explain
Try re-writing it as
[tex]y^\prime = e^{-y/x} + \frac{y}{x}[/tex]
Does a substitution now spring to mind?
yeah i get that... but then i don't know what to do... do we substitute y=vx?
That would indeed be my next step :smile:
lnC + lnx is lnCx yeah?
It is indeed. In general ln(a)+ln(b)=ln(ab).
ok
no matter what i do I'm not getting that answer! and its not supposed to a hard question!
i get this:
y = x lnCx
What do you get after the substitution?
sara_87 said:
ok
i get this:
y = x lnCx
What are the last few steps leading up to your answer? Without seeing your work, it is difficult to say where your error is. Though I am inclined to say that you are probably not taking the natural log of the entire right hand side. That is usually where my error is.
Edit: I notice Hootenany has got you covered. You are in good hands. Back to my DE!
i didn't want to write it out at first because 1. i can't write it the fancy form and 2. I'm affraid i made a very stupid embarrasing mistake, but ok this is what i did:
y' = (e^(-y/x)) + y/x
then y=vx and so v=y/x
d(vx)/dx = (e^(-v)) + v
then i integrate:
vx = x(e^(-v)) + vx + c
then i substituted y back in
is this right so far?
You need to be careful here since v is not a constant, instead it is a function of x, i.e. v=v(x). Therefore, by the product rule,
[tex]\frac{d}{dx}vx = x\frac{dv}{dx} + v[/tex]
Hence, the second line of your working is actually,
[tex]x\frac{dv}{dx} + v = e^{-v} + v[/tex]
Edit: Just to add a little more detail, since v is a function of x, in general,
[tex]\int v(x)dx \neq v\cdot x + c[/tex]
yes yes yes! i see
cheers!
sara_87 said:
yes yes yes! i see
cheers!
No problem :smile:
