Calculating Solar Sail Size for Propulsion Against Sun's Gravitational Force
The discussion revolves around calculating the necessary size of a solar sail to propel a spacecraft against the gravitational force of the sun. It includes theoretical considerations and mathematical reasoning related to solar sailing concepts.
  • One participant inquires about the size of a solar sail needed to propel a 10,000-kg spacecraft against the sun's gravitational force, referencing NASA's interest in solar sailing.
  • Another participant suggests a method to calculate the required sail area by relating the power output of the sun to the gravitational force, introducing variables such as the efficiency of the sail and the distance from the sun.
  • A third participant provides the total power output of the sun as 3.9*10^26 and claims to have calculated a sail area of 0.04 m², but states the actual answer is 6.48 km², which they arrived at through guessing.
  • A fourth participant references the Planetary Society's solar sail project and directs others to a website for additional information on solar sails and related factors.
Participants express differing views on the calculations and assumptions involved in determining the sail size, with no consensus reached on the correct approach or answer.
Key assumptions and variables such as the efficiency of the sail and the specific distance from the sun are not fully resolved, leading to uncertainty in the calculations presented.
desibrij_1785
whats up guys. help me out
NASA is giving serious consideration to the concept of solar sailing. A solar sailcraft uses a large, low-mass sail and the energy and momentum of sunlight for propulsion.
The total power output of the sun is . How large a sail necessary to propel a 10,000-kg spacecraft against the gravitational force of the sun?
Answer must be in km^2
Astronomy news on Phys.org
"The total power output of the sun is . " Was there supposed to be something at the end of that sentence? My guess is that you take the "total power output of the sun" and multiply by the ratio of the size of your sail to the size of the sphere around the sun at your distance (that gives the fraction of the total power that falls on your sail). That should be equal to the force of gravity at that distance.
In fact, if you are clever, you don't need to take distance into account:
Call the total power output (the thing missing from our sentence) "P" and the area of your solar sail "A". If you are "r" meters from the sun, then the total area of the sphere of radius r about the sun is 4πr2 square meters. The fraction of the sun's power that is falling on your sail is A/(4πr2) so the power the sail is receiving is PA/(4πr2). The force of gravity you need to overcome at that distance is GMm/r2. An important number missing from your information is the "efficiency" of your sail: k. The force on your sail due to the "solar wind" will be kPA/(4πr2)= GMm/r2 and the "r2" cancels out: You must have A= 4πGMm/kP.
Apparently you were given "P" and should be able to look up "G" (the universal gravitational constant) and "M" (the mass of the sun). You will also need to know (be given) k (the "efficiency" constant for your sail) and m (the mass of your sail and payload).
power value is 3.9*10^26 and there is no efficiency of the sail. i tried your way and i got answer to be .04 m^2 but actual answer is 6.48 km^2. I got that answer by guessing...
Thanks anyways.
The Planetary Society has a solar sail project. One section of their "Cosmos 1" website is http://www.planetary.org/solarsail/allaboutsolarsails.html , and contains a discussion of the factors of interest. It may not give you exactly what you want, but there's more than enough on the site for you to work out the rest yourself.
  • · Replies 86 ·
9K
  • · Replies 1K ·
36
192K
