Is Induced E.M.F a Force? Understanding Eddy Currents
The discussion revolves around the nature of induced electromotive force (EMF) and its classification as a force, as well as the concept of eddy currents. Participants explore the definitions and implications of these terms within the context of electromagnetic induction and energy losses in electrical systems.
  • Some participants question whether induced EMF can be classified as a force, with one stating that EMF is essentially voltage or potential difference.
  • Another participant clarifies that although "emf" stands for "electromotive force," it is not a force in the traditional sense, referencing historical terminology.
  • It is noted that EMF has units of volts, while magnetomotive force (mmf) has units of amp-turns, indicating a distinction between these concepts.
  • Participants discuss eddy currents as induced currents resulting from time-varying magnetic fields, particularly in ferromagnetic materials, and mention their role in energy losses in transformers.
  • One participant suggests that laminating the core of transformers can mitigate the energy losses associated with eddy currents.
There is no consensus on whether induced EMF should be considered a force, with differing interpretations presented by participants. The discussion includes multiple competing views on the definitions and implications of EMF and eddy currents.
Participants express uncertainty regarding the phrasing of initial questions, which may affect the clarity of the discussion. The historical context of terminology such as "electromotive force" and "magnetomotive force" is also acknowledged, but remains unresolved in terms of its implications for current understanding.
chiakimaron
1. Is it induce e.m.f is a force?
2. What is the eddy current?
I'm sorry but these questions are poory phrased. The way you have used the terms really don't make any sense. I'm assuming English isn't your first language.
Anyway I will attempt to answer the questions that I think you mean to ask. EMF, or Electromotive Force, is to all intents and purposes the voltage. It is a 'force' or 'potential difference' that causes circulation of current/electrons.
An Eddy Current is something that is created in the magnetic iron used in transformers. It is basically a current that is caused within the magnetic core due to the windings. It causes energy losses as the currents cause the core to heat up. These are combated by making an iron core out of electrically insulated laminations of steel rather than a solid block.
EMF is not a force, it is a voltage, or potential difference of the source.
Although "emf" literally stands for "electromotive *force*", it is not really a force. In the early days of investigation into induction, the phrase was coined, as well as "mmf", which stands for "magnetomotive *force*", which also is not really a force in the true sense. Both emf and mmf are related to force.
The emf quantity has units of "volts per turn", whereas mmf has units of "amp-turns". For a simple one turn or one loop circuit, emf is in volts, and mmf is in amps. The emf from point a to b is the total work done per unit charge transporting said charge from a to b along a specified path.
Eddy currents are induced currents due to the presence of a time-varying magnetic field. If a ferromagnetic material has a time changing magnetic flux, induction takes place. Since ferromagnetic materials are also good conductors, the material itself conducts an induced current due to its own magnetic flux. Transformers, motors, and generators are examples of this phenomenon. Laminating the core into layers reduces the power loss associated with this property. Does this help? BR.
  • · Replies 17 ·
  • · Replies 60 ·
