Finding EQ of Motion for Systems of Particles
  • Context: Graduate
  • Thread starter Thread starter K.J.Healey
    Motion
This discussion focuses on finding the effective potential and force between two electrons in particle physics using the Lagrangian framework. The potential is derived from the scattering amplitude calculated via the Born approximation, where the amplitude for two electrons is expressed as A~e^2/q^2, and its Fourier transform yields V~e^2/r. The interaction is mediated by gauge bosons, specifically photons, and the tree-level Feynman diagram illustrates the propagator's role in this interaction. For further understanding, first-quantization techniques and perturbative methods are essential.
  • Understanding of Lagrangian mechanics
  • Familiarity with scattering amplitudes and the Born approximation
  • Knowledge of Fourier transforms in quantum mechanics
  • Basic concepts of gauge bosons and Feynman diagrams
  • Study the Born approximation in detail
  • Learn about Fourier transforms in quantum field theory
  • Explore the role of gauge bosons in particle interactions
  • Review Feynman diagrams and their applications in scattering theory
Students and researchers in particle physics, particularly those interested in quantum mechanics, scattering theory, and the interactions of fundamental particles.
K.J.Healey
This is not homework; I'm currently in my first particle physics course (survey) and I had a question.
Suppose you have some Lagrangian describing a system. Let's say two electrons, with an interaction. How would you go about finding say, the "force" on either particle, or the potential. Even in approximation? What method should I even begin to learn about?
I guess my problem is I understand what's in these density equations, but how do we convert that to anything usable, for things as simple as two electrons? So I'm looking for more methods, than description of the system.
"force" is very little used in particle physics.
The "potential" between two particles is usually found by a circuitous route.
First the scattering amplitude is calculated in Born approximation.
Then the potential is taken to be the Fourier transform of the scattering amplitude.
For instance, the scattering amplitude for two electrons is A~e^2/q^2.
Its Fourier transform is V~e^2/r.
For a good discussion, see the textbook by Zee. In any case, the type of force that you're thinking of is (usually) mediated through by gauge bosons (e.g. photon), and the two particles interact by exchange of such a boson. The tree level Feynman diagram (meaning, no loops) is essentially just the propagator of the photon, and this is, as pam said, [tex]\sim \tfrac{1}{q^2}[/tex] where [tex]q[/tex] is the momentum.
Also, as pam said, to relate this amplitude to semi-classical mechanics, you need to do some first-quantization. In ordinary quantum mechanics, you can solve scattering problems perturbatively using the Born approximation. There the first term in the amplitude is simply the Fourier transform of the intermediate propagator. If you don't mind some math, here is a quick derivation of the Born approximation: http://www.physics.thetangentbundle.net/wiki/Quantum_mechanics/Born_approximation along with a scattering calculation for a Yukawa [tex]\tfrac{e^{-\mu r}}{r}[/tex] type potential http://www.physics.thetangentbundle.net/wiki/Quantum_mechanics/scattering_off_of_a_Yukawa_potential . In the last example you'll see the "photon" propagator pop out at the end, at which point you can make contact with field theory.
  • · Replies 17 ·
  • · Replies 21 ·
  • · Replies 94 ·
