Electric field/charge woed problem
  • Thread starter Thread starter Dx
    Electric
The problem involves calculating the separation distance between two copper pennies after transferring 4 x 1012 electrons from one penny to another. The electrostatic force of attraction between the pennies equals the weight of one penny, which is determined by its mass of 3g and gravitational acceleration of 9.8 m/s2. Using Coulomb's law, the charge of each penny is calculated to be 6.4 x 10-7 C. The final separation distance is determined to be 1.3 mm.
  • Coulomb's law for electrostatic force
  • Understanding of electric charge and elementary charge (1.6 x 10-19 C)
  • Basic physics concepts of weight and gravitational force
  • Ability to solve algebraic equations
  • Study Coulomb's law in detail to understand electrostatic interactions
  • Learn about electric charge quantization and its implications
  • Explore gravitational force calculations and their applications in physics
  • Practice solving problems involving electrostatics and forces
Students in physics, educators teaching electrostatics, and anyone interested in understanding the principles of electric forces and their calculations.
Dx
A copper peny has a mass 3g. A total of 4 x 10^12 electrons are transferred from one neutral penny to another. If the lectrostatic force of attraction between the pennies is equal to the weight of a penny, what is the separatio between them?
what do i do here, i donno where to begin?
Dx :wink:
The problem pretty much tells you what to do. You are told the charge on each penny, so you should be able to set up the expression for the electric force between them (the separation r is unknown). You are also told the mass of a penny, so you should be able to calculate the weight.
Finally, you are told that the electric force is equal to the weight. Set them equal and solve for r.
Don't worry, I can help you with this problem! First, we need to understand the equation for electrostatic force, which is F = k * (q1 * q2) / d^2, where k is the Coulomb's constant (9 * 10^9), q1 and q2 are the charges of the objects, and d is the distance between them. We also know that the weight of a penny is equal to its mass (3g) multiplied by the gravitational acceleration (9.8 m/s^2).
Since the pennies are neutral before the transfer of electrons, we can assume that the charge of each penny is 0. After the transfer, one penny will have a positive charge and the other will have a negative charge. Since we know that 4 x 10^12 electrons were transferred, we can calculate the charge of each penny using the formula q = ne, where n is the number of electrons and e is the elementary charge (1.6 * 10^-19 C).
So, the charge of each penny will be 6.4 * 10^-7 C. Now, we can equate the electrostatic force of attraction to the weight of a penny and solve for the distance between the pennies (d).
F = m * g (weight of a penny)
k * (q1 * q2) / d^2 = m * g
Substituting the values,
9 * 10^9 * (6.4 * 10^-7)^2 / d^2 = 3 * 10^-3 * 9.8
Solving for d, we get d = 0.0013 m or 1.3 mm. This is the separation between the two pennies after the transfer of electrons.
I hope this helps you understand the problem and how to approach it. Let me know if you have any further questions. Good luck!
13K
  • · Replies 26 ·
  • · Replies 28 ·
