QUICK QUESTION: Minimizing Restrictions
  • Thread starter Thread starter banfill_89
The problem involves determining the dimensions of a box with a square base and no top that must contain a volume of 10,000 cm³ while minimizing surface area. The equations used are volume V = x²y and surface area SA = x² + 4xy. By isolating y using the volume equation, y is expressed as y = 10,000/x². The solution yields dimensions of x = 27.1 cm and y = 13.6 cm, with the constraint that x must be greater than or equal to 5 cm.
  • Understanding of volume and surface area equations for geometric shapes
  • Knowledge of optimization techniques in calculus
  • Familiarity with algebraic manipulation and isolation of variables
  • Basic concepts of constraints in mathematical problems
  • Study optimization techniques using calculus, focusing on critical points and constraints
  • Learn about Lagrange multipliers for handling constraints in optimization problems
  • Explore geometric properties of boxes and their implications on volume and surface area
  • Practice solving similar optimization problems involving different shapes and constraints
Students studying calculus, particularly those focusing on optimization problems, as well as educators looking for examples of real-world applications of mathematical concepts.
banfill_89
Question: a box with a square base and no top must have a volume of 10,000cm^3. if the smallest dimensions in any direction is 5cm, the determine the dimensions of the box that minimize the amount of material used.
V=x^2&y
SA=x^2+4xy
(isolate for y using given volume in V equation to obtain y=10,000/x^2)
SA=x^2+4x(10,000/x^2)
when solved...x=27.1
y= 13.6I have an answer on what the dimensions are, but what do i use as my limitations besides what my x values are. I know i have to use x>or=5...for some reason i can never figure these limitations/restrictions out...
"must have a volume of 10,000cm^3" Sounds like a restriction to me.
