| Thread Closed |
Volumetric Strain - HELP! |
Share Thread | Thread Tools |
| Apr8-08, 09:34 AM | #1 |
A rectangular steel bar has length 250 mm, width 50 mm, and thickness 25 mm. The bar is subjected to a compressive force of 450 kN on the 250 mm x 50 mm face, a tensile force of 450 kN on the 250 mm x 25 mm face, and a tensile force of 45 kN on the 50 mm x 25 mm face. (a) Find the change in volume of the bar under the force system. 2. Relevant equations The forces can be assumed to be uniformly distributed over the respective faces. Take E = 200 kN/mm[tex]^{2}[/tex] and Poissons ratio = 0.26 3. The attempt at a solution I have calculated [tex]\sigma[/tex]x = -0.036 kN/mm[tex]^{2}[/tex], [tex]\sigma[/tex]y = 0.072 kN/mm[tex]^{2}[/tex] and [tex]\sigma[/tex]z = 0.036 kN/mm[tex]^{2}[/tex]. With these values, using Hooke's Law: [tex]\epsilon[/tex] = 1/E[[tex]\sigma[/tex]1 - [tex]\upsilon[/tex]([tex]\sigma[/tex]2 + [tex]\sigma[/tex]3)] I have calculated: [tex]\epsilon[/tex]x = 3.6x10[tex]^{-4}[/tex], [tex]\epsilon[/tex]y = -3.204x10[tex]^{-4}[/tex] and [tex]\epsilon[/tex]z = 1.332x10[tex]^{-4}[/tex]. Furthermore, using the equation for volumetric strain: [tex]\nabla[/tex]V/Vo = [tex]\epsilon[/tex](1-2[tex]\upsilon[/tex]) I have calculated the change in volume to be 25.92 mm[tex]^{2}[/tex]. This, according to the answer I have been provided with, appears to be incorrect. I would appreciate any guidance with this. |
| Apr8-08, 10:13 AM | #2 |
Hi cicatriz, welcome to PF. Try using this equation for change in volume:
[tex]\Delta V=V_0\left[(1+\epsilon_1)(1+\epsilon_2)(1+\epsilon_3)-1\right][/tex] I'm not sure how the other one was derived (hydrostatic pressure maybe?) but it doesn't look right. I checked your strain values and they look fine. The change in volume should be about twice what you got previously. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Volumetric Strain - HELP!
| volumetric strain | Engineering, Comp Sci, & Technology Homework | 3 | ||
| Chemistry - Volumetric determination | Biology, Chemistry & Other Homework | 1 | ||
| Volumetric Analysis | Chemistry | 1 | ||
| Help A Car Guy Out (Volumetric Efficiency) | General Physics | 9 | ||
