Thread Closed
complex analysis
Share Thread Thread Tools
Apr9-08, 07:41 AM   #1
complex analysis
Also when trying to find the integral of (1/8z^3 -1) around the contour c=1.
I found the singularities to be 1/2, 1/2exp(2pi/3), and 1/2exp(4pi/3)
What is the next step here. Do I just assume the integral is 6pi(i) after using partial fractions to find the numerators of the 3 fractions.
The answer is actually 0, but I dont understand how it was solved. I know it might have something to do with the rule that says, the sum of the integral of a C1, C2 and C3 is equal to the integral of the outside contour, but how do i know the orientation of the three contours inside the big contour C.
Thanks, hope im not asking too many questions
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Apr9-08, 07:55 AM   #2
Find the function's residue at each of the poles inside the contour. Then use the residue theorem.
Apr9-08, 08:11 AM   #3
Quote by Pere Callahan View Post
We haven't covered residue theorem yet. Is there any other way to solve it?
Apr9-08, 08:15 AM   #4
complex analysis
Quote by soulsearching View Post
Of course there is. Find a parametrization of the contour and do it by hand.
In general if you want to evaluate
[tex]
\int_C dz f(z)
[/tex]
where C is the contour, you can find a parametrization
[tex]
\gamma : [0,1]\to \mathbb{C}
[/tex]
such that [itex]\gamma([0,1])=C[/itex] (formalities omitted - you are certainly familiar with that )
Then your integral becomes
[tex]
\int_0^1 dt f(\gamma(t))|\gamma'(t)|
[/tex]
This will give a not-too eays but doable integral. Note however, that normally it works the other way around. If you have some definite real integral, you can sometimes try to interpret it as a complex integral over a closed contour and use the residue theorem to evaluate it, but that's a different story.
Apr9-08, 08:44 AM   #5
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Hi soulsearching!
I'm a little confused (especially by the 6πi).
Are you saying that you know how to integrate (1/2z - 1) round a contour containing z = 1/2?
If so, just use the same contour for all three partition fractions!
Apr9-08, 09:13 AM   #6
Quote by tiny-tim View Post
Hi soulsearching!
Like after breaking up the fraction into 3 fractions using partial fractions, what's the next step?
Thanks... :)
Apr9-08, 09:22 AM   #7
Recognitions:
Life after breaking up the fraction into 3 fractions using partial fractions, what's the next step?
erm … if you don't know how to integrate (1/2z - 1) round a contour containing z = 1/2, then there is no next step … you're stuck (or, rather, you have to follow Pere Callahan's method)!
So … do you know ? … you didn't say.
Apr9-08, 09:39 AM   #8
I think its going to be 2pi(i) because the singularity (1/2) is inside the contour. is this right?
Apr9-08, 09:40 AM   #9
i did not get Pere Callahan's method. and why did you choose the contour as z=1/2? the question says integrate it around z=1
Apr9-08, 10:18 AM   #10
Recognitions:
No, I said a contour containing z = 1/2.
You're getting confused between z = 1/2 (a point) and |z| = 1/2 (a circle) … I did warn you about that in another thread … you must write |z| when you mean it, or you'll lose track.
The integral, of course, is the same for any contour that includes the same singularities.
So you could, for example, choose the contour |z| = 100!
And then integrate all three partial fractions round that.
erm …
I can't remember! …
but I know it's 1/2 times something.
Thread Closed
Thread Tools
Similar Threads for: complex analysis
Thread Forum Replies
Complex analysis Calculus 7
Advice on complex analysis, Riemann surface & complex mappings. Differential Geometry 3
complex cosine equation (complex analysis) Calculus & Beyond Homework 2
complex analysis Calculus & Beyond Homework 11
complex analysis - LFT Calculus 6
