Thread Closed
[Vibration analysis] Timoskenko beam Vs.Euler-bernoulli beam ?
Share Thread Thread Tools
Apr9-08, 10:21 AM   #1
ACT
Hello,
I am looking for explanations and detailed studies or even brief ones about the differences in Vibration analysis and dynamic studies as well as static analysis between
Timoskenko beam and .Euler-bernoulli beam
when should i use Euler-bernoulli beam?
Thanks
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Apr14-08, 01:39 PM   #2
Hi.As far as I know Timoshenko beam model includes the effect of shear efforts which is usually neglected when dealing with slender beams. The most of the beams you will encounter are slender (steel beams for example), which are much longer than wide so unless you're analyzing concrete beams (which are usually not so slender) I think you can use the Euler-Bernoulli beam,it's simpler.
Regards.
Michujo.
Apr14-08, 01:43 PM   #3
Recognitions:
Gold Membership Gold Member
I already told you the difference in another thread, why create another thread and ask again?
Thread Closed
Thread Tools
Similar Threads for: [Vibration analysis] Timoskenko beam Vs.Euler-bernoulli beam ?
Thread Forum Replies
Do you calculate the amount of load a beam can take based on when the beam cracks? Materials & Chemical Engineering 6
Beam Analysis Engineering, Comp Sci, & Technology Homework 5
Cantilever Beam Analysis Classical Physics 2
Forced Vibration on a Cantilever Beam Classical Physics 1
Forced Vibration of a Cantilever Beam Mechanical Engineering 2
