Energy momentum tensor of a scalar field by varying the metric
The discussion revolves around the derivation of the energy-momentum tensor for a scalar field by varying the metric in the context of general relativity. Participants explore the implications of different formulations of the Lagrangian and the resulting expressions for the energy-momentum tensor.
  • One participant presents a Lagrangian for a scalar field and derives the energy-momentum tensor by varying the metric, leading to a proposed expression for \( T^{\mu \nu} \).
  • Another participant challenges the correctness of the variation process, suggesting that derivatives of the scalar field must be included and providing an alternative derivation of the energy-momentum tensor.
  • A later reply emphasizes the importance of correctly handling variations of the metric and the implications for the derived expressions.
  • Participants discuss the relationship between variations of the metric and the resulting signs in the energy-momentum tensor, noting that the order of operations affects the outcome.
  • There is a debate over the appropriate form of the Lagrangian, with participants arguing for different conventions regarding the use of covariant and contravariant indices.
  • One participant expresses confusion about the apparent contradiction arising from the variations and seeks clarification on the correct treatment of the metric variations.
  • Another participant suggests that varying and raising indices do not commute, which complicates the derivation process and the resulting expressions.
  • There is acknowledgment that the choice of Lagrangian formulation influences the sign of the terms in the energy-momentum tensor, leading to further discussion on which formulation is more natural.
Participants generally agree on the need to carefully consider the variations of the metric and the implications for the energy-momentum tensor. However, there is no consensus on the correct formulation of the Lagrangian or the resulting expressions for the energy-momentum tensor, with multiple competing views remaining.
Participants highlight potential limitations in their derivations, including the dependence on the chosen form of the Lagrangian and the handling of metric variations. Unresolved mathematical steps and assumptions regarding the treatment of indices are also noted.
knobelc
Suppose you are given the Lagrangian of a scalar field [tex]\Phi(t)[/tex]
[tex]\mathcal{L} = \frac{1}{2} \dot{\Phi}- \nabla \Phi - V(\Phi ).[/tex]
By introducing covariant notation with [tex]\eta_{\mu \nu} = (1,-1,-1,-1)[/tex] this reads as
[tex]\mathcal{L} = \frac{1}{2} \eta^{\mu \nu} \partial_\mu\Phi \;\partial_\nu\Phi- V(\Phi ).[/tex]
Let us now switch to GR, i.e. $\eta^{\mu \nu} \rightarrow [tex]g^{\mu \nu}[/tex]. The Lagrangian remains the same since covariant derivative of a scalar field is the same as normal derivative, i.e. [tex]\nabla_{\mu} \Phi = \partial_{\mu} \Phi[/tex]. I derive the energy-momentum-Tensor [tex]T^{\mu \nu}[/tex] by varying [tex]g_{\mu\nu}[/tex] in the action
[tex]S = \int \mathcal{L} \sqrt{-g}\; dx^4,[/tex]
i.e.
[tex]\delta S = \frac{1}{2}\int T^{\mu \nu} \delta g_{\mu\nu} \sqrt{-g}\; dx^4.[/tex]
So we obtain with the variation [tex]\delta g_{\mu\nu}[/tex]
Sorry, I had some problems with the latex here. So I could not finish my first posted text. Here is the full version:
Suppose you are given the Lagrangian of a scalar field [itex]\Phi(t)[/itex]
By introducing covariant notation with [itex]\eta_{\mu \nu} = (1,-1,-1,-1)[/itex] this reads as
Let us now switch to GR, i.e. [itex]\eta^{\mu \nu} \rightarrow g^{\mu \nu}[/itex]. The Lagrangian remains the same since covariant derivative of a scalar field is the same as normal derivative, i.e. [itex]\nabla_{\mu} \Phi = \partial_{\mu} \Phi.[/itex] I derive the energy-momentum-Tensor [itex]T^{\mu \nu}[/itex] by varying [itex]g_{\mu\nu}[/itex] in the action
i.e.
[tex]\delta S = \delta \int \mathcal{L} \sqrt{-g} \;dx^4 = \int \left[\left( \frac{\partial \mathcal{L}}{\partial (\nabla_\mu \Phi)} \;\delta (\nabla_\mu \Phi) + \frac{\partial\mathcal{L}}{\partial g_{\mu\nu}} \;\delta g_{\mu\nu} \right) \sqrt{-g} + \mathcal{L} \;\delta (\sqrt{-g}) \right]dx^4.[/tex]
Since our Lagrangian does not contain any covariant derivative [itex]\delta (\nabla_\mu \Phi)=0.[/itex] Furthermore it holds
[tex]\frac{\partial\mathcal{L}}{\partial g_{\mu\nu}} = \frac{\partial}{\partial g_{\mu\nu}} \left[\frac{1}{2} g_{\mu\nu} \partial^\mu\Phi \;\partial^\nu\Phi\right] = \frac{1}{2} \partial^\mu\Phi \;\partial^\nu\Phi[/tex]
and it is well known in GR that
[tex]\delta(\sqrt{-g}) = \frac{1}{2}g^{\mu\nu} \sqrt{-g}\; \delta g_{\mu\nu}.[/tex]
So we obtain finally
[tex]\delta S = \frac{1}{2} \int \left[ \partial^\mu\Phi \;\partial^\nu\Phi + g^{\mu\nu}\mathcal{L} \right]\delta g_{\mu\nu} \sqrt{-g}\; dx^4,[/tex]
thus
[tex]T^{\mu \nu} = \partial^\mu\Phi \;\partial^\nu\Phi + g^{\mu\nu}\mathcal{L}.[/tex]
My problem is now that the correct result should read as
[tex]T^{\mu \nu} = \partial^\mu\Phi \;\partial^\nu\Phi - g^{\mu\nu}\mathcal{L}.[/tex]
Thus I get the sign in the second term wrong. Where is the error?? Sorry for this subtle problem but I have looked at it again and again and don't see it. So I would be happy if anybody could help me.
Your variation isn't going correctly. First of all, your action contains derivatives of the scalar field, so you should include those. Covariant derivatives on scalar fields equal partial derivatives on scalar fields.
If one has the action
[tex] L = \sqrt{g}{\cal L} = \sqrt{g}\Bigl(g^{\mu\nu}\partial_{\mu}\phi\partial_{\nu}\phi -V(\phi)\Bigr)[/tex]
I obtain when varying with respect to the metric ( varying with respect to the scalar field will give me the equations of motion, which are known I assume )
[tex] \delta L = \delta {\cal L} \sqrt{g} + {\cal L}\delta\sqrt{g} = ( \delta {\cal L} + \frac{1}{2}{\cal L}g^{\mu\nu}\delta g_{\mu\nu} )\sqrt{g}[/tex]
which equals
[tex] (\frac{1}{2}\delta g^{\mu\nu}\partial_{\mu}\phi\partial_{\nu}\phi + \frac{1}{2}g^{\mu\nu} {\cal L }\delta g_{\mu\nu})\sqrt{g}<br /> [/tex]
Now remember that
[tex] \delta g^{\mu\nu} = -\delta g_{\mu\nu}[/tex]
and you obtain
[tex] \delta L = \frac{1}{2} \sqrt{g}(g^{\mu\nu}{\cal L} - \partial_{\mu}\phi\partial_{\nu}\phi)\delta g_{\mu\nu}[/tex]
From this you can easily obtain the energy momentum tensor. If I didn't make typos, that is.
That was a quick answer from a long night drinking; ofcourse the last term should be
[tex]\delta L = \frac{1}{2} \sqrt{g}(g^{\mu\nu}{\cal L} - \partial^{\mu}\phi\partial^{\nu}\phi)\delta g_{\mu\nu}[/tex]
Thanks a lot for your quick answer. Still there remains for me a paradox:
First of all, the correct formula is
[tex]\delta g^{\mu\nu} = -g^{\mu \alpha}g^{\beta \nu}\delta g_{\alpha\beta}[/tex].
The whole paradox for me is then
[tex]\delta g_{\mu \nu}\;\partial^{\mu}\phi\partial^{\nu}\phi = \delta(g_{\mu \nu}\partial^{\mu}\phi\partial^{\nu}\phi)[/tex]
[tex]= \delta(g^{\mu \nu}\partial_{\mu}\phi\partial_{\nu}\phi)[/tex]
[tex]= \delta g^{\mu \nu}\;\partial_{\mu}\phi\partial_{\nu}\phi[/tex]
[tex]= -g^{\mu \alpha}g^{\beta \nu}\delta g_{\alpha\beta}\;\partial_{\mu}\phi\partial_{\nu}\phi[/tex]
[tex]= - \delta g_{\mu \nu}\;\partial^{\mu}\phi\partial^{\nu}\phi[/tex]
This is a contradiction unless [itex]\delta g_{\mu \nu} = 0[/itex]. This makes the difference between your and my solution. Can you resolve this?
Maybe it's a little overdone, but my view on this is the following. Varying and raising indices don't commute. So,
[tex] [\delta, g_{\mu\nu}] \neq 0[/tex]
This looks quite trivial, but it has consequences. When I wrote
[tex] \delta g_{\mu\nu} = -\delta g^{\mu\nu}[/tex]
I ment explicitly
[tex] (\delta g)_{\mu\nu} = -(\delta g)^{\mu\nu}[/tex]
You're used to freely change the position of the indices in a contraction, so eg for tensors of rank one,
[tex] X_{\alpha}Y^{\alpha} = X^{\alpha}Y_{\alpha}[/tex]
However, this is not allowed when you consider variations which concern that object with which you raise and lower those indices: the metric itself! So I would say that
[tex] \delta(g^{\mu \nu}\partial_{\mu}\phi\partial_{\nu}\phi) \neq \delta(g_{\mu \nu}\partial^{\mu}\phi\partial^{\nu}\phi)[/tex]
This can be traced back by the fact that
[tex] g_{\mu\nu}g^{\nu\rho} = \delta_{\mu}^{\rho} \rightarrow \delta\Bigl(g_{\mu\nu}g^{\nu\rho}\Bigr) = 0 \rightarrow \delta g_{\mu\nu} g^{\nu\rho} = - g^{\nu\rho}\delta g_{\mu\nu}[/tex]
which creates that minus-sign. In fact, what you should have is
[tex] \delta(g^{\mu \nu}\partial_{\mu}\phi\partial_{\nu}\phi) = - \delta(g_{\mu \nu}\partial^{\mu}\phi\partial^{\nu}\phi)[/tex]
It may look strange that lowering or raising indices on a tensor induces a minus-sign, but that's only when you look at the variation of the metric, which is a tensor. Ofcourse, this doesn't influence the transformation properties of the object, so it's still a tensor.
If anyone else has other ideas about this, I'm very interested :)
I agree that
[tex]\delta(g^{\mu \nu}\partial_{\mu}\phi\partial_{\nu}\phi) = - \delta(g_{\mu \nu}\partial^{\mu}\phi\partial^{\nu}\phi)[/tex],
but then problem arises that the way we write the Lagrangian determines the sign of the first term in the energy-momentum-tensor. How can we decide what way to write the Lagrangian, i.e. either
[tex]L = \sqrt{g}{\cal L} = \sqrt{g}\Bigl(g^{\mu\nu}\partial_{\mu}\phi\partial _{\nu}\phi -V(\phi)\Bigr)[/tex]
or
[tex]L = \sqrt{g}{\cal L} = \sqrt{g}\Bigl(g_{\mu\nu}\partial^{\mu}\phi\partial^{\nu}\phi -V(\phi)\Bigr)?[/tex]
I tend to the answer that the first version is the more natural since it contains the "physical" derivation
[tex]\partial_{\mu} = \frac{\partial}{\partial x^\mu},[/tex]
instead of
[tex]\partial^{\mu} = \frac{\partial}{\partial x_\mu}[/tex]
which can only be defined by means of a metric, the object to be varied.
[tex]\delta_{g}\left( g^{ab} A_{a}B_{b}\right) = \delta g^{ab} A_{a}B_{b}[/tex]
or
there is no problem you can use any one.
Because [itex]\mathcal{L}(g^{ab}) = \mathcal{L}(g_{ab})[/itex], you need to decide about the sign so that you always have
[tex]T^{ab} \delta g_{ab} = - T_{ab} \delta g^{ab}[/tex]
So when you take
[tex]\delta \sqrt{-g} = \frac{1}{2} \sqrt{-g} g^{ab} \delta g_{ab}[/tex]
you must then take
[tex]\delta \mathcal{L} = \frac{ \partial \mathcal{L} }{ \partial g^{ab} } \delta g^{ab} = - \frac{\partial \mathcal{L}}{\partial g_{ab} } \delta g_{ab}[/tex]
the second equality follows from the identity
[tex]\left[ \delta g^{ab} = - g^{ac} g^{bd} \delta g_{cd} \ \right][/tex]
Thus
[tex] \delta S = \frac{1}{2} \int dx \sqrt{-g} \left( \mathcal{L} g^{ab} - 2 \frac{\partial \mathcal{L}}{\partial g_{ab}} \right) \delta g_{ab}[/tex]
Then from
[tex]\delta S = \int dx \sqrt{-g} \frac{\delta S}{\delta g_{ab}} \delta g_{ab} \equiv - \frac{1}{2} \int dx \sqrt{-g} \ T^{ab} \delta g_{ab}[/tex]
you find
[tex]T^{ab} = 2 \frac{ \partial \mathcal{L}}{\partial g_{ab}} - g^{ab} \mathcal{L}[/tex]
But if you take
[tex]\delta \mathcal{L} = (+) \frac{\partial \mathcal{L}}{\partial g_{ab}} \delta g_{ab}[/tex]
then you should write
[tex]\delta \sqrt{-g} = (-) \frac{1}{2} \sqrt{-g} g^{ab} \delta g_{ab}[/tex]
and define the T-tensor by
[tex]\delta S = \frac{1}{2} \int dx T^{ab} \delta g_{ab}[/tex]
Personally I use and stick to the followings
[tex]\delta \sqrt{-g} = - \frac{1}{2} \sqrt{-g} g_{ab} \delta g^{ab}[/tex]
[tex]\delta \mathcal{L} = \frac{\partial \mathcal{L}}{\partial g^{ab}} \delta g^{ab}[/tex]
[tex]\delta S = \frac{1}{2} \int dx \ \sqrt{-g} T_{ab} \delta g^{ab}[/tex]
this again leads to the correct T-tensor
[tex]T_{ab} = 2 \frac{\partial \mathcal{L}}{\partial g^{ab}} - g_{ab} \mathcal{L}[/tex]
regards
sam
samalkhaiat said:
So when you take
you must then take
Why is that? Is this just a rule in order to get the "right" result? Without any further information I don't see a reason not to write
[tex]\delta \mathcal{L} = \frac{\partial \mathcal{L}}{\partial g_{ab} } \delta g_{ab} = - \frac{ \partial \mathcal{L} }{ \partial g^{ab} } \delta g^{ab}[/tex]
in this case. Or do I miss something?
Cheers, C.
Exactly! you need your T-tensor,defined in GR to be
[tex]T^{ab} = -2 \frac{\delta S}{\delta g_{ab}} \ \ (1),[/tex]
to agree with the (symmetric) canonical tensor, derived from Noether theorem,
[tex]T^{ab} = \frac{\partial \mathcal{L}}{\partial \partial_{a} \phi} \partial^{b} \phi - \mathcal{L} g^{ab}[/tex]
Can you derive Eq(1) within the canonical formalism? No you can not. So you need a sigh manifesto.
Yes, You would get an incorrect canonical energy-momentum tensor.
regards
sam
  • · Replies 68 ·
  • · Replies 16 ·
  • · Replies 38 ·
