Thread Closed
[SOLVED] Angular speed problem
Share Thread Thread Tools
Apr9-08, 08:22 PM   #1
A cylinder with mass m1 = 4.00kg, and radius 30cm, rotates about a vertical, frictionless axle with angular velocity of 8.00 rev/s. A second cylinder, this one have a mass of m2 = 3.00kg, and radius 20cm, initially not rotating, drops onto the first cylinder. Because of friction between the surfaces, the two eventually reach the same angular speed.
A) calculate the final angular speed
B)Find the energy lost in the system due to the interaction of the two cylinders.
3. The attempt at a solution
Just wondering if this is right:
I converted the 8 rev/s to 50.265 rad/s. I wasn't sure if i needed to but I did it anyway.
[tex] L_{i} = L_{f}[/tex]
[tex]I_{1}\omega_{1i}^2 = (I_{1} + I_{2})\omega_{f}^2[/tex]
[tex]\omega_{f} = \sqrt{\frac{I_{1}\omega_{1i}^2}{(I_{1} + I_{2})}} [/tex]
[tex] = \sqrt{\frac{(.5)(4)(0.3^2)(50.265^2)}{(0.5)(4)(0.3^2) + (0.5)(3)(0.2^2)}[/tex]
= 43.53 rad/s
Then for part B, I found the loss of energy due to friction using the change in kinetic energy.
[tex]0.5(I_{1} + I_{2})\omega_{f}^2 - 0.5(I_{1})\omega_{f}^2^2 [/tex]
[tex] 0.5[(0.5)(4)(0.3^2) + (0.5)(3)(0.2^2)](43.53)^2 - 0.5((.5)(4)(0.3^2)(50.265)^2
[/tex]
= 51.17 J
Did I solve this problem correctly?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Apr9-08, 08:48 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Angular momentum is [tex]L = I\omega [/tex]. [tex]\omega [/tex] is NOT squared.
Apr9-08, 08:49 PM   #3
crap. Other then that is that the right process (don't mind the numbers now)
Apr9-08, 08:58 PM   #4
Recognitions:
Yes, I think your approach is OK.
Thread Closed
Thread Tools
Similar Threads for: [SOLVED] Angular speed problem
Thread Forum Replies
[SOLVED] Angular Speed Introductory Physics Homework 6
[SOLVED] angular speed. Introductory Physics Homework 6
[SOLVED] Torque & Angular Speed Introductory Physics Homework 2
I need help on this problem about angular speed. Introductory Physics Homework 2
angular speed problem.. Introductory Physics Homework 1
