Is Electron Spin Just a Mathematical Concept?
The discussion centers on the nature of electron spin, exploring whether it is merely a mathematical concept or if it has physical significance. Participants examine the implications of electron spin in quantum mechanics, its relationship to angular momentum, and its representation in various models.
  • Some participants suggest that electron spin is a mathematical entity rather than a physical rotation, noting that electrons do not spin on their axes.
  • Others argue that experiments, such as the Einstein-de Haas effect, demonstrate that electrons possess angular momentum, implying a physical reality to spin.
  • One participant elaborates on the wave function of the electron, describing how spin contributes to a magnetic moment density and suggesting that this effective current is a result of the spin density.
  • Concerns are raised about the interpretation of electron spin, with references to resources stating that it should not be viewed as a classical analogue, emphasizing its quantum nature.
  • Some participants discuss the implications of treating the electron as a point particle, noting that this characterization complicates the notion of spin and angular momentum.
  • There are references to the challenges of modeling the electron as a spinning sphere, with discussions on the limitations of classical analogies in explaining quantum phenomena.
Participants express a range of views on the nature of electron spin, with no consensus reached. Some support the idea of spin as a mathematical construct, while others argue for its physical implications based on experimental evidence.
Participants highlight limitations in classical models when applied to quantum mechanics, particularly regarding the interpretation of charge and mass in relation to point particles. There are unresolved questions about the nature of the electron's magnetic moment and the implications of vacuum polarization effects.
Dahaka14
It is true that electrons don't actually "spin" on their own axes according to their intrinsic spin, but this trait is simply a mathematical entity, correct?
Hi Dahaka14! :smile:
Either Feynman or Aitchison & Hey (I can't find the actual quote) point out that if you fire a beam of electrons with a particular spin at a disc that is free to spin, then the disc will spin … thereby proving that electrons really do have an angular momentum, and not just a "theoretical spin"! :smile:
See also the Einstein-de Hass effect.
Electron spin is angular momentum without rotation of the electron.
This angular momentum can be imparted to other objects that spin.
The notion that objects have to rotate to have angular momentum is classical,
but not in relativistic QM.
The electron's wave function is considered to be a continuous distribution of charge
and spin. (Pauli-Weisskopf) Each point of the wave function is assigned a charge
density, a current density, but also an axial current density. (the spin)
So, each point of the wave function has a spin-density giving rise to a magnetic
moment density. The volume integral of the magnetic moment density gives the
total magnetic moment [itex]\mu_e[/itex].
Spin does represent an effective current cycling around the wave-function as
a whole. (for example, see Sakurai, Advanced QM, section 3-5, Gordon decomposition)
This is due to Stokes law and equivalent to what happens in a magnetic material:
The "little circular currents" inside the material cancel each other but at the edge
they do not and sum up to an effective electric current around the material as
a whole.
This effective current around the wave function is given by the curl of the spin density.
When this effective current is used to calculate the magnetic moment, then again
the integral over space leads to the magnetic moment [itex]\mu_e[/itex].Regards, Hans
However, don't forget that the electron (in current physics) is a point particle, so it has no axis around which to spin. It's simply an inherent property that shows up in interactions with other quanta.
I did check the Einstein-de Hass effect, and it seemed convincing, but I found resources that continue to state that electron spin is not to be taken literally as with the classical analogue:
"The property called electron spin must be considered to be a quantum concept without detailed classical analogy...The term "electron spin" is not to be taken literally in the classical sense as a description of the origin of the magnetic moment described above. To be sure, a spinning sphere of charge can produce a magnetic moment, but the magnitude of the magnetic moment obtained above cannot be reasonably modeled by considering the electron as a spinning sphere."
I got this from hyperphysics, but I can't have the URL because I haven't made 15 posts yet...
The magnetic moment can not be derived simply by "rotating" the charge density.
You would end up with speeds higher as the speed of light.
This doesn't mean there is a conflict with for instance Maxwell's laws. The charge we
measure is not the bare charge. It is screened by vacuum polarization effects where
the vacuum can contains equal amounts of negatively and positively charged virtual
particles. We don't know what the bare charge of the electron is, neither do we know
what exactly causes the magnetic moment, neutral particles can have a magnetic
moment as well. For instance a particle with a counter rotating antiparticle produces
a magnetic moment while being electrically neutral. Regards, Hans
A "point particle" is more a way of saying that we do not observe a composite
structure for the electron in scattering experiments.
Strictly speaking, a point particle can not have an electric charge either since it would
lead to infinite energies and it can't have mass since a radius smaller as the Schwartz-
schild radius would result in a black hole.
For practical purposes, as for instance molecular modeling, one uses the distributed
charge and spin densities of the wave function and the electric and magnetic fields
they produce. The EM fields seen by other particles are then determined by integrating
over the entire wave function.Regards, Hans
I remember a post on this forum, about detection of rotation of a "perfect sphere": an object with perfect spherical symetry. We could not assign any direction to such object, so we could not define angular velocity as a time derivative of the angle between that direction and coordinate system.
But if the sphere would have mass and charge, then it would have both angular momentum and magnetic moment: just like electron. I think we could imagine electron as a very small charged ball with perfect spherical symmetry.
For some problems which arise from such a simple model, see for instance:
The Feynman lectures on physics, volume II, chapter 28.
Regards, Hans
  • · Replies 45 ·
