Is getting stabbed by an IC pin a cause for concern?
  • Thread starter Thread starter seang
    Doctor
The discussion revolves around the potential health risks associated with accidentally stabbing oneself with an integrated circuit (IC) pin, particularly concerns about lead poisoning and infection from puncture wounds. Participants share their experiences and advice regarding safety and first aid in such situations.
  • One participant expresses concern about lead poisoning from an IC pin.
  • Another participant suggests that the risk of lead exposure is minimal compared to other sources, such as food or solder smoke.
  • A third participant advises using standard first aid practices for treating a small puncture wound, emphasizing the importance of cleanliness to reduce infection risk.
  • A participant asserts that IC pins are not made with lead and downplays the risk of lead poisoning.
  • One comment humorously exaggerates the situation, suggesting a dire outcome.
  • A participant shares personal experience with lead-based solder, indicating that solid lead exposure from component leads is not a significant concern, but notes that precautions would be necessary for finely divided lead forms.
Participants exhibit disagreement regarding the health risks associated with lead exposure from IC pins, with some downplaying the concern while others express worry. The discussion remains unresolved on the extent of risk and appropriate responses.
There are varying assumptions about the materials used in IC pins and the nature of lead exposure, which may affect the participants' perspectives on health risks.
seang
just stabbed myself with an IC pin.
lead poisoning?
lol its not RoHs compliant chip? how many pins did you stab yourself with? chances are we absorbed more lead in food/solder smoke, paint
Just use standard first aid practice for a small puncture wound -- wash it out well with soap and water. As long as it was a relatively clean pin, the risk of infection is low.
Those dang pins hurt!
There's no danger of lead poisoning. IC pins aren't made with lead anyway, and even if they were you'd still be fine.
- Warren
you have more 24 hours to live
good luck
I've repaired lots of old tube amps over the years, and I got "stuck" by tinned component leads (with lead-based solder) more times that I can count. I never worried about the lead because it was solid and metallic. If it were finely divided or in the form of lead oxide, then I'd take precautions. Ah, the heady smell of rosin-core solder!
  • · Replies 24 ·
