Conservation of Energy and Centripetal Motion Question
The discussion focuses on the physics problem involving a skier on a hemispherical hill, specifically determining the height at which the skier leaves the surface. The conclusion is that the skier becomes airborne at a vertical distance of h = R/3 from the top of the hill, despite initial calculations suggesting R/2. Key equations used include the centripetal force equation, ΣF = mv²/r, and the conservation of energy equation, mgΔy = 1/2 mv². The analysis emphasizes the importance of understanding the relationship between the skier's velocity and the angle of descent.
  • Understanding of centripetal motion and forces
  • Familiarity with conservation of energy principles
  • Knowledge of basic trigonometry and angles in physics
  • Ability to manipulate equations involving mass, gravity, and radius
  • Study the relationship between centripetal acceleration and gravitational force
  • Learn how to derive velocity in terms of angle using conservation of energy
  • Explore the concept of normal force in non-horizontal motion
  • Investigate the dynamics of motion on curved surfaces
This discussion is beneficial for physics students, educators, and anyone interested in understanding the principles of motion on curved surfaces and the application of energy conservation in real-world scenarios.
cblack
A skier starts at rest on the top of Mt Circular, a strange, smooth, icy hill shaped like a hemisphere. The hill has a constant radius of R. Neglecting friction (it is icy!), show that the skier will leave the surface of the hill and become air-borne at a vertical distance of h=R/3, measured from the top of the hill.
[tex]\Sigma[/tex]F=mv[tex]^{2}[/tex][tex]/[/tex]r
mg[tex]\Delta[/tex]y=[tex]\frac{1}{2}[/tex]mv[tex]^{2}[/tex]
I have found one question exactly like this one on the forum and I understand that when the skier leaves the hill, the normal force will be 0, but I keep getting R/2 as an answer.
[tex]\Sigma[/tex]F=Fn+mg
0=[tex]\Sigma[/tex]F-mg
0=[tex]\frac{mv^{2}}{R}[/tex]-mg
v=[tex]\sqrt{gR}[/tex]
Substituting this into the conservation of energy equation you get:
mg[tex]\Delta[/tex]y=[tex]\frac{1}{2}[/tex]mgR
[tex]\Delta[/tex]y=[tex]\frac{mgR}{2mg}[/tex]
[tex]\Delta[/tex]y=[tex]\frac{R}{2}[/tex]
Is it reasonable to assume that the skier is in centripetal motion?
The only thig i don't understand is how the skier can have a normal force of zero at any other point than at [tex]\frac{R}{2}[/tex] because at the point the angle between the skier and the vertical will be 90 degrees. If you use the equation [tex]\Sigma[/tex]F=mgcos[tex]\Theta[/tex]+mg where mgcos[tex]\Theta[/tex], which is the noraml force, can only equal 0 at 90 degrees. If the skier is leaving somewhere between 0 and 90 degrees how can this be calculated?
hello cblack, your physical concept is correct. you almost got it. you just left out [tex]\theta[/tex] somewhere it should be.
try to find v in terms of [tex]\theta[/tex] using conservation of E.
then construct equation of motion. Be careful the v here also relates to [tex]\theta[/tex]. then you can solve for [tex]\theta[/tex] :smile:
Realize that the weight acts vertically, not centripetally. (Find the radial components of the forces.)
  • · Replies 22 ·
