From The Suns Core to The Corona?
  • Context: Undergrad
  • Thread starter Thread starter Eric DMC
    Core Corona
This discussion revolves around the journey of photons from the core of the Sun to its corona, exploring the time it takes for light to travel this distance and the mechanisms involved. Participants examine concepts related to photon behavior, gravity's effect on time, and the diffusion process of light in a dense medium like the Sun.
  • Some participants question why photons take so long to travel from the Sun's core to the corona, suggesting that they zigzag due to absorption and re-emission processes.
  • One participant proposes a thought experiment regarding gravity's effect on time, speculating that photons might experience time differently due to the Sun's mass.
  • Another participant clarifies that the mass and density of the Sun are insufficient to produce significant time dilation effects compared to those near a black hole.
  • It is noted that photons are absorbed and re-emitted multiple times, which contributes to the long travel time, likening the process to a "drunkard's walk."
  • A participant introduces the concept of mean free path, providing a formula related to photon interactions within the Sun.
Participants express differing views on the implications of gravity on photon travel time and the nature of photon movement within the Sun. While some agree on the mechanisms of absorption and re-emission, there is no consensus on the broader implications of gravity and time dilation in this context.
Participants mention the complexity of photon interactions in a dense medium and the limitations of applying concepts from black hole physics to the Sun's core. The discussion highlights the need for careful consideration of definitions and assumptions regarding light propagation and time.
This discussion may be of interest to those studying astrophysics, particularly in understanding stellar processes, photon behavior in dense media, and the effects of gravity on light. It may also appeal to individuals curious about the nature of light and time in different gravitational contexts.
Eric DMC
Last night I watch a show about the birth of our sun on the Science channel. At one point they talked about how it takes thousands of years for the light in the suns core to travel from the center to the Corona "outer shell", and then only 11 minutes for the light to travel from the Corona to earth.
There explanation why it took so long for it to travel from the center to the Corona did not set right with me. It was explained that the photons do not slowdown; it took so long because they travel in a zigzag pattern. Witch brought up a question, what causes the photons to zigzag?
Then I thought about how gravity affects time, what if the photons still travel in a straight line but the massive gravity of the sun slows time? To us the observers it would take thousands of years for the photons to travel from the Core to the Corona. But to the photon "if it could sense time" would take merely minutes.
Now as I was writing this I remember that the speed of light is a constant, never changing!
Can some one explain this? What causes the photons to zigzag? And how wrong is my slowed time thought? Because I know it is!
You are right that gravity affects time and a photon sent down to near the event horizon of a black hole and reflected back would take longer than the distance divided by the speed of light. The mass and density of the sun is too insignificant to produce the sort of time dilation mentioned in that program. The gas in the sun is a plasma and photons coming from the centre are probably absorbed and re-emitted in random directions thousands of times. You also have to take account of refractive index. A light signal sent down a long fibre optic would take longer than a signal traveling the same distance through a vacuum. Before anyone asks if the speed of light is actually slower in a medium like glass, look up phonons. ;)
Thanks for explaining, so black holes can slowdown a photon? I thought that light was a constant and never changed speeds.
Eric, you are thinking too Euclidean here. Spacetime in the vicinity of a black hole is stretched. That said, this has very little to do with the amount of time it takes light to go from the center of the Sun to the surface of the Sun.
It appears you are envisioning a single photon traveling from the center of the Sun to the surface. That is not what happens. The fusion reactions at the center of the Sun create high energy gamma rays. Matter is quite dense near the core. Think of it as shining a flashlight in a very thick fog.
Imagine a gamma photon created by a fusion reaction. This gamma photon will not travel very far; some other ion will absorb it. The original photon travels at the speed of light, but only for a short distance before being absorbed. The absorbing ion will re-radiate the absorbed energy, but in a random direction, at a reduced frequency, and this does not happen immediately. The same thing happens with the new photons released by the ion that absorbed the original gamma. The photons bounce around and around. This is called a diffusion process. Another name is a drunkard's walk. Eventually, after bouncing around, the original energy will leave the sun, but it takes a lot of bounces.
mean free path
I found a note I made that
mean free path = 1 / [tex]\kappa[/tex] [tex]\rho[/tex]
where [tex]\kappa[/tex] is opacity
and
[tex]\rho[/tex] is density
Can someone confirm this?
  • · Replies 33 ·
  • · Replies 57 ·
  • · Replies 25 ·
  • · Replies 18 ·
  • · Replies 32 ·
  • · Replies 19 ·
