What is the frequency of a mass-spring system oscillation?
The frequency of oscillation for a mass-spring system can be determined using the formula f = (1/2π) * √(k/m), where k is the spring constant and m is the mass of the object. In this scenario, the spring constant k can be expressed as k = (mg/yi), allowing for the cancellation of mass when calculating frequency. The system oscillates with a maximum displacement of 21 cm below the initial position, confirming that it exhibits simple harmonic motion (SHM). The analysis confirms that the oscillation frequency can be derived from the relationship between gravitational force and spring force.
  • Understanding of simple harmonic motion (SHM)
  • Familiarity with Hooke's Law and spring constants
  • Basic knowledge of energy conservation in mechanical systems
  • Ability to manipulate algebraic equations involving mass and spring constants
  • Explore the derivation of the spring constant k using Hooke's Law
  • Study the principles of energy conservation in oscillating systems
  • Learn about the characteristics of simple harmonic motion (SHM)
  • Investigate the effects of varying mass on the frequency of oscillation
Students studying physics, particularly those focusing on mechanics and oscillatory motion, as well as educators seeking to explain the principles of mass-spring systems and SHM.
ThePhoenixEffec
A massless spring hangs from the ceiling with a small object attached to its lower end. The object is initially held at rest in a position yi such that the spring is at its rest length. The object is then released from yi and oscillates up and down, with its lowest position being 21 cm below yi.
What is the frequency of the oscillation?
T = 2pi sqrt(m/k)
Analyzing the forces,
At the rest position:
Fnet = k(yi) - mg = o
k(yi) = mg
Maximum distance below the rest position,
Fnet = k([tex]\Delta[/tex]y)
I know that the total energy of the system is given by the following:
E= U + K = 1/2k(A)^2
Since I finding frequency I can just take the reciprocal for the equation for period:
f = (1/2pi)*sqrt(k/m)
I don't have any masses given so I'm assuming that I have to find the analytic solution for k that will cancel out the m.
I know that k = (mg/yi) but I wasn't given what yi is.
I'm think I have to do something with the energy of the system.
I really think I need more information, but there must be some way to solve this problem.
The first step is to prove that an oscillating body hanging from a spring executes SHM.
Let a body of mass m hang in equilibrium by stretching the spring by a length of x1. Then,
mg = kx1.
(Edited:)
Now suppose the spring is stretched by a dist x2 from its unstretched length position. Write down the force eqn and prove that it is indeed an SHM. (Consider x=x2-x1.)
After that, you can use all the results of SHM.
