| Thread Closed |
Gravitational Potential Energy |
Share Thread |
| Apr14-08, 04:16 PM | #1 |
The problem states that: "Bruce stands on a bank beside a pond, grasps the end of a 10.0m long rope attached to a nearby tree and swings out to drop into the water. If the rope starts at an angle of 35 degrees with the vertical, what is Bruce's speed at the bottom of the swing?
Variables: angle of the rope with the vertical: 35 degrees Length of rope: 10m I'm trying to use the equation for the change in gravitational potential energy, where the Work due to gravity = -mg(yf-yi) which is equal to Kf-Ki, and therefore -mg(yf-yi)= -1/2mvi^2+-1/2mvf^2. With the initial velocity as 0 and the masses canceling out the solution should be Vf=[tex]\sqrt{}[/tex]2g(yf-yi). I am apparently either setting up the question wrong, or going about it wrong all together. I'm pretty much stumped as to what I'm doing wrong and how to fix it. If someone could point me in the right direction I'd be ecstatic... |
| Apr14-08, 05:03 PM | #2 |
There is nothing wrong with your setup. Why do you think that there is?
| Apr14-08, 08:46 PM | #3 |
I thought I was doing it right, but the website we use to submit our homework wasn't accepting the answer I got from the formula. Thanks.
| Apr15-08, 09:39 AM | #4 |
| Apr16-08, 08:18 AM | #5 |
That's okay. I think I know what happened. I probably rounded off to the wrong number is all. A similar thing happened in another homework assignment after I posted the question. Thankfully I caught that one before I ran out of chances to answer the question.
| Thread Closed |
Similar discussions for: Gravitational Potential Energy
| Transformation of Kinetic and Gravitational Potential Energy:Conservation of Energy. | Introductory Physics Homework | 9 | ||
| gravitational potential energy-help! | Introductory Physics Homework | 5 | ||
| Gravitational Potential Energy | Introductory Physics Homework | 5 | ||
| Gravitational Force, the derivative of Gravitational Potential Energy? | Classical Physics | 3 | ||
| Gravitational Potential Energy | Classical Physics | 9 | ||
