Determining charges of elements
  • Thread starter Thread starter amd123
    Charges Elements
This discussion focuses on determining the charges of elements using the periodic table, particularly for high school students. It highlights that while Group 1 and 2 elements have predictable charges of +1 and +2 respectively, transition metals exhibit variable charges due to their d-orbitals, necessitating memorization of common charges such as Chromium (IV), Chromium (VI), and Iron (III). The conversation also notes that for A-group elements, charges can be inferred based on their group position, with Halogens typically having -1 charges and Chalcogens -2.
  • Understanding of the periodic table structure
  • Basic knowledge of element groups (A-group elements)
  • Familiarity with transition metals and their properties
  • Concept of noble gases and their electron configurations
  • Research the properties of transition metals and their variable charges
  • Study the electron configurations of elements, focusing on d-orbitals
  • Learn about periodic trends and how they affect element charges
  • Memorize common oxidation states of key transition metals
This discussion is beneficial for high school chemistry students, educators teaching periodic table concepts, and anyone seeking to understand the charge determination of elements in chemistry.
amd123
I know its a rather simple question but if you think about it, it requires much knowledge of d orbital. Is there an easy way a HS student can determine charges of elements using only a periodic table and no prior knowledge of orbitals? My old chem teacher said you could take the element and count backwards from the nearest noble gas, but this doesn't work all the time :(
Chemistry news on Phys.org
Well, the transition metals (the bulk of the table in the center) are weird and don't follow any particular easy rules. They also have the issue of having variable charges and such due to that d-orbital, so really, the only way I've ever seen to know them is to just memorize the common charges for each element. Chromium (IV), Chromium (VI), Mercury (II), Iron (III), etc. It's a bit of a pain.
Through for the A-group elements (or Groups 1, 2, then 13 to 18 on your new-fangled Periodic Tables), you can tell charge based on what group they're in. Group 1 and 2 elements have +1 and +2 charges, then jumping across the trans-metals Boron's group has +3, Carbon's +4, and Nitrogen's +5. As suggested for the last two groups you can as a rule of thumb count back from the Noble Gases to guess the charge. The Halogens have -1 charges, the Chalcogens (Oxygen's group) are -2. Period Law is fun, but complicated at times.
  • · Replies 19 ·
11K
13K
  • · Replies 28 ·
  • · Replies 28 ·
