Thread Closed
Electric Circuit Connected to Ground
Share Thread Thread Tools
Apr15-08, 07:14 AM   #1
Given the attached scheme, if [tex]R_{1}[/tex]=[tex]R_{2}[/tex]=[tex]R_{3}[/tex]=10 Ω and [tex]\epsilon_{1}=20 V[/tex] , [tex]\epsilon_{2}=10 V[/tex] determine the potentials at the points A,B,C,D,E. The sources of emf have no internal resistance.
2. Relevant equations
My question is: Why is it that no current exists along the branch BE? If one made this particular apparatus I am convinced he would observe no current. But in theory, why does this happen? Shouldn't the source of emf [tex]\epsilon_{2}[/tex] produce some current?
And even if [tex]\epsilon_{2}[/tex] , [tex]R_{3}[/tex] did not exist, why would the current ''choose'' to move around the loop instead of going towards the ground?
3. The attempt at a solution
Assuming no current exists at the branch BE, we assign zero potential at points D,E. Because of [tex]\epsilon_{2}[/tex] we have [tex]V_{B}=-10 V[/tex].
Due to our assumption, current exists only within the loop. We easily find its value:
[tex]I=1 A[/tex]. Using the mathematical expression of Ohm's law we may now easily obtain the wanted potentials:
[tex]V_{A}=0 V[/tex] , [tex]V_{C}=-20 V[/tex]
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Apr15-08, 11:01 AM   #2
There is no return path for the current. If there was a current from B to E, the electrons would either pile up somewhere in the loop or the loop would get depleted of electrons.
What would happen if you connected the loop to point B is that a current would flow for a very short time, until a very small negative charge is distributed around the loop. This charge would prevent any further electrons going through the loop through BE. Their electric field would be the source of the overall negative potential of the loop.
(It's much easier to forget about this and just go with: "no closed loop - no current")
Thread Closed
Thread Tools
Similar Threads for: Electric Circuit Connected to Ground
Thread Forum Replies
[SOLVED] Putting a ground in between circuit Engineering, Comp Sci, & Technology Homework 9
Electric ground?! Classical Physics 5
Is every subspace of a connected space connected? General Math 12
Electric Circuit Electrical Engineering 2
Electric Circuit HELP! Introductory Physics Homework 6
