What is the source of electrons in generators and how are they replenished?
The discussion centers on the source of electrons in electrical generators and how they are replenished, particularly in the context of one-way current flow versus closed circuits. Participants explore the nature of electron movement in circuits and the role of grounding in electrical systems.
  • One participant questions the source of electrons in generators, suggesting that there cannot be an endless supply and inquires about how electrons are replenished.
  • Another participant explains that in closed circuits, electrons circulate continuously, and in AC systems, they oscillate back and forth.
  • A participant proposes that the ground acts as a source of electrons for generators, likening it to a well drawing from an underground lake.
  • Another participant challenges the idea of a "sink" for electrons, asserting that appliances are part of a closed circuit and that electrons are not consumed.
  • One participant emphasizes that the ground is primarily for safety and not for carrying load, noting that most household devices do not rely on grounding for operation.
  • Questions arise regarding the energy used to power appliances and its origin, with an analogy drawn to hydroelectric plants where water is not consumed but changes potential energy.
Participants express differing views on the role of the ground in supplying electrons and the nature of current flow in circuits. There is no consensus on the source of electrons or the implications of grounding in electrical systems.
Some participants rely on analogies to explain concepts, which may introduce assumptions about the behavior of electrons and energy in circuits. The discussion reflects varying interpretations of electrical principles without resolving these differences.
extant
scenario:
If any generator ultimately 'pushes' current (free surface electrons) down a wire, moving trillions of trillions of electrons through power wires towards our homes and other uses . . .
what is the source of electrons at the generator site to replenish electrons? There can not be an endless supply, so where are they initially taken from, and how are electrons returned to this starting point of electrical generation (in this specific example or in general for non-cyclic systems).
The electrical circuits are closed loops. The electrons just go all the way round and start the journey again. Thats for DC. If it's AC, they oscillate, moving one way then back again repeatedly.
fair enough for a conventional circuit, but i was asking about a situation where current is sent one way only, down a line to a "sink" for the electrons (appliances and whatever).
I think i have found the answer that there is a component of the system in the ground. It is the ground itself that supplies (effectively) an endless supply of electrons for the generator (ie hydroelectric power plant). (Similar to a well drawing from an underground lake that is immediately, and constantly refilled as water is pumped out)
If this needs correction or some specific detail on how the electrons are drawn out of the ground, I would appreciate it, but I am otherwise satisfied with the general explanation.
The current is never sent 'one way', that's why there are two wires. There's no such thing as a sink for electrons. If your appliance is running, it is part of a closed circuit and the same electrons flow around the circuit. They are not in any sense 'used up'.
Where did you find this ? I think you've got it wrong.
extant said:
I think i have found the answer that there is a component of the system in the ground. It is the ground itself that supplies (effectively) an endless supply of electrons for the generator (ie hydroelectric power plant). (Similar to a well drawing from an underground lake that is immediately, and constantly refilled as water is pumped out).
If you have more than a tiny amount of current in your ground wire, you have a serious problem. The ground is there for protection only, not for carrying load. Note that most household electrical devices are not grounded - they only have two-prong plugs.
but then, what energy that was used to turned on all these appliances? where did it come from?
Again, the best way to think about it is probably with an analogy to a hydroelectric plant. The water goes through the plant, but is not consumed in the process. When it gets out at the bottom of the dam, it is just at a lower [gravitational] potential than before it went through the dam/plant. An electron going through a resistor works the same way. A force (also called "potential") is required to push the electron through a resistor (that's where the name "resistor" comes from) and after going through the resistor, the electron has a lower electrical potential than it did before it went through.
  • · Replies 38 ·
9K
12K
22K
