Evaluating Limit: tan(π/4 + 2h) / h using Trig Addition Formula
  • Thread starter Thread starter Flappy
    Limit
The discussion revolves around evaluating the limit of the expression \(\lim_{h\rightarrow0}= \frac{\tan(\frac{\pi}{4}+2h) - \tan\frac{\pi}{4}}{h}\), which involves trigonometric functions and their properties. The problem is situated in the context of calculus, specifically dealing with limits and derivatives.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the use of the trigonometric addition formula and discuss algebraic manipulation to simplify the limit. Some suggest using L'Hospital's Rule, while others question the appropriateness of this approach given the context of the limit. There are also discussions about the implications of canceling terms and the validity of different methods.
The conversation is ongoing, with various methods being proposed and debated. Some participants express uncertainty about the algebraic steps taken, while others suggest alternative approaches, such as L'Hospital's Rule or using Taylor series. There is no clear consensus on the best method to proceed, and participants are actively questioning assumptions and interpretations.
There is a noted confusion regarding the application of L'Hospital's Rule, particularly in relation to the definition of the derivative and the limit process. Participants are also discussing the relevance of certain trigonometric identities and their application in this context.
Flappy
[tex]\lim_{h\rightarrow0}= \frac{tan(\frac{\pi}{4}+2h)\ - tan\frac{\pi}{4}}h[/tex]
Here's what i was able to work out.
Use the trig addition formula:
[tex]\lim_{h\rightarrow0}= \frac{(\frac{tan\frac{\pi}{4}+ tan2h}{1-tan\frac{\pi}{4}tan2h}) - tan\frac{\pi}{4}}h[/tex]
Get the LCD of 1 - tan(pi/4)tan2h, then multiply by 1 - tan(pi/4)tan2h to get rid of the fraction.
[tex]\lim_{h\rightarrow0} = \frac{tan\frac{\pi}{4} + tan2h - tan\frac{\pi}{4}(1 - tan\frac{\pi}{4}tan2h)} {h(1- tan\frac{\pi}{4}tan2h)}[/tex]
The last two terms cancel out:
[tex]\lim_{h\rightarrow0} = \frac{tan\frac{\pi}{4} + tan2h - tan\frac{\pi}{4}}h[/tex]
You're left with:
[tex]\lim_{h\rightarrow0} = \frac{tan2h}h[/tex]
Then i believe you would need to use the double angle formula?
[tex]\lim_{h\rightarrow0} = \frac{\frac{2tanh}{1-tan^2h}}h[/tex]
multiply to get rid of fraction
[tex]\lim_{h\rightarrow0} = \frac{2tanh}{h(1 - tan^2h)}[/tex]
And this is where I got stuck, any suggestions?
sin(h)/h -- > 1 as h-->0 ** [edit Thanks]
Can also use L'Hospital's Rule.
Taylor Series ..
Do you have to stick with canceling stuff out algebraically?
If not just L'Hopital that sucker.
You should get 2.
Okay.
Whoa, wait, what happened to the rest of the denominator, and other term in the numerator?
rootX said:
sin(h)/h -- > 1 as h-->1
Taylor Series ..
sin(h)/h =/ ->1 as h ->1.
lim as h-> 1 of sin(h)/h = sin1
I think you're mixing it up with that one fact lim as x -> 0 of sinx/x = 1 or something like that.
Using L'Hospital here would be putting the cart before the horse, since it requires already knowing what the derivative of tan() is, no?
Can't use l'hospital's rule since the problem is given as a limit h--> 0. They don't give f(x)
"Whoa, wait, what happened to the rest of the denominator, and other term in the numerator?"
They cancel out, don't they?
Flappy said:
Can't use l'hopitals rule since the problem is given as a limit h--> 0.
Why would that stop you?
Nope.
yeah, I was just kidding about that whole "2" business. The answer is actually 4. And I double checked myself this time.
I'm assuming that you were taught that lim as h->0 of f(x) is the format you're used to, right?
Here f(x) is not explicitly defined as such but the the fraction which you a taking the limit of is itself a function of the variable h so the same rules and concepts will apply. And since you get the case 0/0 you can go right ahead and l'hopital it.
and to qudraphonics: do many people learn l'hopital's rule before they learn the derivative of tan(u)?
I learned the derivative of tan(u) before I learned L'Hospital's rule, IIRC. But the point is that the limit in question is the definition of the derivative of tan(u) (well, up to that factor of 2), so it's sort of circular to suggest using L'Hospital's rule, which gives the answer in terms of the derivative of tan(u). I suppose you could apply enough trig identities so that it's no longer expressed in terms of tan(), and then apply L'Hospital to that (assuming you already know the derivative of the various trig functions in the expression).
However, now it occurs to me that maybe this problem is aimed at people who already have learned all of the derivatives in question, as well as L'Hospital's rule, and they're just checking that you understand the effect of including the extra factor of 2 ("extra" compared to the definition of the derivative). In which case, L'Hospital away!
The point people are trying to make is that tan(2h)= sin(2h)/cos(2h).
[tex]\frac{tan(2h)}{h}= \frac{sin(2h)}{h}\frac{1}{cos(2h)}= 2\frac{sin(2h)}{2h}\frac{1}{cos(2h)}[/tex]
Now, what is the limit of that?
16K
